Vacuum line, no start issue
Old Sep 17, 2012 | 01:50 PM
worldclasssniper's Avatar
worldclasssniper
Long story short had a small fire when the front pump seal gave out on the tranny of my 1997 f350 with the 460 and 4wd.
Once the fire was out we did a damage assessment and a bunch if the vacuum lines were melted. We fixed and replaced all but 1, the one that goes to the fuel tanks... Can't find the connecting line behind the motor and back to the tank. Regardless of that, the truck started and we ran it up the street, no issues, went to do a 3 pt turn, put it in reverse, it died, and then wouldn't start again. We have fuel pressure, and spark. Did a deep dig in search of wires that were melted and found nothing. All grounds still in tact. The motor turns over strong, but no start. Any thoughts or suggestions?
Oh btw I pulled codes and it showed none
Old Sep 17, 2012 | 02:16 PM
Truckin Bob's Avatar
Truckin Bob
Just for grins.......I'd cap off all of the unnecessary vacuum lines on the vacuum tree and go from there.
The "stock" vacuum system was engineered as a balanced system (small restrictive lines, check valves, bleed off, funneled down connectors, etc.) and if you haven't "matched" the system exactly, you'll have problems.
Just my thought,
Bob
PARATROOPER82
21
Mar 26, 2015 05:56 PM
claytonk
Feb 21, 2012 11:49 PM
RIKIL
Jun 13, 2010 08:46 PM
dilbone56
May 22, 2007 06:55 AM
bluneon
Apr 19, 2006 05:37 PM
