ABS light on?
Old Sep 15, 2012 | 08:11 AM
Rocketattack's Avatar
Rocketattack
ABS light on?
My truck is a '94 F350 CC Dually 4x2. I don't drive much , only on weekends. The past two weekends the ABS has come on then off. Any ideas what would cause this? I know there is some kinda weight switch on the axle to apply more brake when there is more weight. As the trucks has no fuel in rear tank, no spare tire or any weight on the back. Could this be causing this?
Old Sep 15, 2012 | 02:43 PM
airdale94's Avatar
airdale94
The sensor in the differential might be bad or just dirty.
Old Sep 16, 2012 | 08:51 AM
whalebus2112's Avatar
whalebus2112
usually its the rear wheel speed sensor that is in the the top side pinion side rear hog head. just remove 1 screw and it pulls straight out. Very common problem
Old Sep 16, 2012 | 09:09 PM
Onus's Avatar
Onus
Most people don't know but the abs system computer stores codes, and they can be pulled. So you don't have to guess replacing stuff.
02f350gurl
Dec 16, 2010 07:36 PM
gdombroski
Nov 3, 2008 03:20 PM
woody1003
19
Jan 5, 2008 07:09 PM
saka
1997 - 2003 F150
Dec 7, 2006 05:56 PM
ChevmaninaFord
1997 - 2003 F150
Dec 14, 2005 11:05 AM
