8x165 Wheel Question
Old Sep 14, 2012 | 11:25 PM
willworship's Avatar
willworship
I've searched through a bunch of posts, and I'm getting some conflicting information, so I was hoping someone could clear it up. I currently have 8-lug 16.5" wheels with 33 all-terrains on it, and I am looking to get more "road-friendly" tires on some 16" wheels (so the tires will be cheaper and easier to find). I have found a local guy who has some newer (they look like aftermarket) 8x165s with 225/75/16 tires that he took off a 71 Chevy C20 that he says should fit my truck (his listing says pre 99 Ford and Dodge), but I cannot find any hub/center bore measurements for wheels that fit his truck. He is going to measure tomorrow, but I was hoping someone could give me some guidance here.
Thanks for your help!
Old Sep 15, 2012 | 12:35 AM
burnout400m's Avatar
burnout400m
The bolt patterns are the same but IIRC the chevy centers are smaller than ford so a factory chevy wheel won't fit unless you open up the center hole.
Old Sep 15, 2012 | 07:45 AM
willworship
I'm hoping these wheels happen to have a larger center bore... That would be convenient. From what I have found, I need 124.9mm/4.92in in the center, right?
Old Sep 15, 2012 | 07:59 AM
Diesel_Brad's Avatar
Diesel_Brad
You need a 8 on 6.5"(165.1mm) bolt pattern and the hub hole needs to be 4.88"(123.95mm)
EDIT: This is the correct hub diameter
Old Sep 15, 2012 | 08:17 AM
willworship
Excellent. Thanks!
Old Sep 15, 2012 | 05:40 PM
Diesel_Brad
Sorry. I misspoke earlier the correct hub diameter is 4.88 And I corrected post above
Old Sep 15, 2012 | 05:50 PM
willworship
Thank you for following up with that, Brad. That gives me a little more hope that they might fit.
Here is what they look like: wheels
(Mods, please delete the link if it is not allowed - I couldn't find anything saying it was not permitted)
Old Sep 15, 2012 | 07:38 PM
Diesel_Brad
I am sure they will be fine since they are aftermarket. American racing made those, but I can't remember what the name was.
Also, I hope you do not have 4:10 gears because those little(225) tires will make it SCREAM on the highway
Old Sep 15, 2012 | 07:48 PM
willworship
I'm pretty sure it had smaller tires (than 33's) to begin with, because the speedometer is WAY off (13 mph at highway speeds).
Old Sep 15, 2012 | 08:33 PM
Diesel_Brad
That is odd. a 33 is 32.6" tall and a 235/85/16(stock size) is 31.7" tall. That should NOT equate to 13 mph off. @ 65 you speedo should read 62-63mph with your current 33" tires
Old Sep 15, 2012 | 09:19 PM
willworship
My truck is such a frankenstein, I have no idea what "stock" would equal on it.
All I know is that when my speedometer reads 65 mph, I'm actually going 78 mph. I almost got in trouble when I first bought the thing, because I had no idea.
It's an inline 6 300 with a M5OD... I wonder if a previous owner put the factory speed sensor on a replacement tranny, or vice versa? Part of the fun of acquiring an old truck is trying to figure out how it got the way it is...
Old Sep 15, 2012 | 09:24 PM
willworship
If it does scream with the 225s on it, I will definitely switch up to the 235s. I'm mainly trying to get these for the 16" wheels so my tires will be cheaper. Those 16.5" wheels make finding adequate tires pretty painful on the wallet.
Old Sep 16, 2012 | 07:37 AM
Diesel_Brad
What year is your truck. IIRC the F250s only came with the ZF5
Old Sep 16, 2012 | 07:47 AM
willworship
It's an 89. When I took the tranny off to replace the clutch, pressure plate, and the internal slave cylinder (which was leaking and the cause of the problem) right after I bought it, the best I could tell from other descriptions was that it was a M5OD, but I could definitely be wrong. That was my first tranny work.
Any clues to telling the difference?
Old Sep 16, 2012 | 08:15 AM
Diesel_Brad
A ZF5 will have pro covers a MOD5 will not.
Sounds like you need to change the gear that goes into your t-case for the speedo
