adjusting unadjustable timing
Old May 16, 2003 | 01:05 AM
mcne's Avatar
mcne
Has anyone played around with the timing on late eighties trucks? Mine is and 87 F-150 with the 4.9 and the book says it is not adjustable. I have tried to adjust it years ago before I found out it wasn't adjustable. I didn't notice any big difference when I tweaked it, but with it barely running I might try to play with it again just to see. When I hook up my timing light where should the mark be aligned on the block? There are several teeth and one bigger notch on the row of teeth. I am assuming the bigger notch is the point of stock alignment? I checked it and believe it is at 15 degrees. It does not change throughout the rpm band. Is this normal? I thought the computer changed the timing with the rpms?
Old May 16, 2003 | 10:35 AM
steve83's Avatar
steve83
Look at the emissions sticker in the engine compartment - it has the procedure for setting the timing.
The SPOUT connector should be taped into the wiring harness within ~3" of the ignition module on the base of the distributor.
