03 Ranger A/C Problem-Help Appreciated!!
Old Sep 14, 2012 | 12:26 PM
waits3's Avatar
waits3
Hey guys, I have an 03 Ford Ranger 4x4. Great truck and runs great just with one small problem. For whatever reason, every single time, the a/c only blows un-cool air (not hot) when I start the truck. Then, and only then, after about 30-40 mins of constant driving around does the a/c start working properly and blowing COLD air. After that it works great but it always takes about 30 mins after I start the truck for it to work correctly. Any help on this would be greatly appreciated!!
Old Sep 14, 2012 | 12:57 PM
cracked block's Avatar
cracked block
Could be the a/c compressor relay. This happened to my car. Good luck, but someone with more knowledge will be posting later.
Old Sep 14, 2012 | 01:26 PM
waits3's Avatar
waits3
Thank you!!
Old Sep 14, 2012 | 10:09 PM
B2500's Avatar
B2500
Bleed Air out of Cooling System
waits3, While researching the cooling system I saw this video that says air in the cooling system causes all kinds of heating & cooling oddities. Easiest thing to do first is bleed your cooling sys.; here is the link:
https://www.youtube.com/watch?v=zUpX...eature=related
Let us know if this solves your problem.
Old Sep 15, 2012 | 12:48 AM
Dutter's Avatar
Dutter
i dont see how draining your coolant effects your AC, there two totally separate systems. I think your thinking of a heater and the heater core, because that uses your coolant to warm up the core, were ther AC has its own system that you charge,
fordcourierboy
Apr 13, 2008 04:01 AM
fordrangergirl
Sep 2, 2004 10:22 PM
wrexpower
Apr 6, 2004 08:02 AM
