down for the count
Old Sep 12, 2012 | 11:13 PM
sand_fiend's Avatar
sand_fiend
I wounder if you got the wrong flex plate to begin with ?
And like what was said. if the starter gear was not retracting all the way back in. it would drag on the flex plate a little at a time and eventually machine the teeth off.
If your crank was that far out, or out in any manner. you would loose MASSAVE oil out of the rear seal. There is no way it would not leak oil...
you could of had gotten a bad flex plate to begin with. It happens, it could have been slightly bent also..
Old Sep 12, 2012 | 11:19 PM
sand_fiend's Avatar
sand_fiend
Originally Posted by FUJINAMI1293
so maybe i should take it to ford see what they have to say?
Don't take it to ford !!!!
Old Sep 13, 2012 | 10:43 AM
SteveH-CO's Avatar
SteveH-CO
Avoid Ford - they will likely soak you $2K by the time you're out of there. I would either find a Ford diesel-savvy mechanic, or DIY and post photos here. This forum will have all the expertise you need.
gear_head28
Oct 24, 2013 07:13 PM
ndreb
6.4L Power Stroke Diesel
15
Dec 20, 2011 06:19 AM
1988F-150
Sep 29, 2009 08:17 PM
gilbo
Modular V10 (6.8l)
Nov 3, 2005 03:25 AM
GregTruck
Oct 22, 2004 12:49 AM
