Vacuum leak help
Old Sep 12, 2012 | 06:02 PM
johngeorge's Avatar
johngeorge
Vacuum leak help
I have a 95 F150 and the air will start blowing in the floor under acceleration and back to the dash registers when I let off so I figure I have a vacuum leak somewhere. My question is: Are there any typical areas to inspect first before I start going through everything in the dash? Thanks
Old Sep 12, 2012 | 10:51 PM
rla2005's Avatar
rla2005
Start with the white vacuum hose that leads to the HVAC system, it's under the hood on top of the blower motor/heater/evaporator box. VERY common problem.
Old Sep 13, 2012 | 11:18 AM
Truckin Bob's Avatar
Truckin Bob
And check the vacuum cannister (coffee can) for leaks.
Bob
Old Sep 13, 2012 | 11:44 AM
Puddy's Avatar
Puddy
There is also a connector under the dash in the middle, should be a half moon clear connector with a few lines, check and see if it's loose or rubbed on some of the dash bracing
Old Sep 13, 2012 | 01:04 PM
nintey4f150's Avatar
nintey4f150
whats the best way to replace that white line? i notice it goes into one of the harnesses
Old Sep 13, 2012 | 01:15 PM
rla2005's Avatar
rla2005
IMHO....pull that crappy white vinyl/plastic line all the way out of the bundle and replace all of it. For that matter replace all the under hood vacuum lines, all of them are a vacuum leak just waiting to happen.
Old Sep 13, 2012 | 01:36 PM
nintey4f150
i honestly dont even kno where the two ends connect too.. mine is disingrated lol
wirebender
Jul 23, 2018 09:26 PM
BRONC-OH
1997 - 2003 F150
Aug 24, 2017 09:04 AM
pcdocta
43
Mar 19, 2017 04:16 PM
rollbutt
Jun 18, 2011 11:57 PM
landjr
Jul 11, 2005 08:56 PM
