brake line question
Old May 15, 2003 | 06:39 PM
dickboyd69's Avatar
dickboyd69
brake line question
I have a 77 f-150 4wd with disc brakes on the front. I just bought this truck a while ago and need to bleed the brakes. I was bleeding the fr and checked the master cylinder. Instead of fluid being drawn out of the front like I was used to it pulled it out of the back reservoir. Is this normal? All of the other trucks I have worked on the front brakes drew fluid of the front. The front line on the master cylinder goes to the back on the proportioning valve. The lines look original. Also you can get them switched because they are different sized fittings. This truck has never stopped good. Is this the reason why? How should the lines go? Thanks.
Richard
Old May 15, 2003 | 07:35 PM
Mil1ion's Avatar
Mil1ion
brake line question
The primary (Front Brakes) reservoir is the LARGEST one & is usually closest to the firewall.
You didn't bleed this way:
RR - LR - RF - LF ?
Old May 16, 2003 | 07:13 AM
dickboyd69's Avatar
dickboyd69
brake line question
Hey thanks Dennis.
I just wanted to make sure they were hooked up right. Oh and no I bled them rr rl fr fl. Thanks again.
Richard
Old May 16, 2003 | 09:55 PM
amwxx's Avatar
amwxx
brake line question
man you did bleed them the same way, you just wrote it different.
Old May 17, 2003 | 09:41 AM
dickboyd69's Avatar
dickboyd69
brake line question
ya i did didn't i don't know where my head was the other day
