Dash Gauge Mount
Dash Gauge Mount
Anybody running the Autometer 15003 two gauge dash mount?
Thinking this might be perfect for my Fuel Pressure and HPOP gauges.
I would like to see what it looks like mounted up...
Autometer 15003
EDIT: Found one...
https://www.ford-trucks.com/forums/9...ml#post8857671
Autometer 15003
EDIT: Found one...
I like this one better than the dash mount above the radio, and overhead by the mirror. My only concern is if it blocks the fuel gauge, temp gauge, etc in the corners. My second choice would be the lower panel by the 4x4 shifter, similar to the 650 location. I wonder if it would be in the way of my trailer brake controller though...
Warning lights with dash suround pod - YouTube
Gives you a bit of an idea of how the dash one blocks gauges and such...
I chose this set up to avoid the pillar mount. For me, that set up is too distracting for night driving. Any additional guages will go down in the lower panel. The lights the dash mount pod blocks are the parking brake, WTS, ABS, and a couple others that don't come to mind right now. If you really need to see them, you can sort of look around the gauge if necessary. The temp and fuel guages are not blocked.
turned on:
By Joe's video, it doesn't appear to block too much of the outer gauges. I like the more heads up view, although I wont be watching them as often. I also have the Prodigy controller and the lower one didn't appear to block it as much as I had expected. The only other gauge I might add down the road would be bag pressure.... I'm torn, luckily I don't need to decide now!
