10.25 gears interchangeable?
Old 09-10-2012, 01:27 PM
Johnny L's Avatar
Johnny L
Johnny L is offline
I have an '88 F350 with 10.25 rear axle and D60 kingpin front axle. 3.55 gears. I have 35" tires and a ZF5 transmission so I would like to get 4.10 gears. It's pretty sluggish with 3.55's, although it's good at highway speeds.
My question is this:
Can I swap in 4.10 gears from a '93 F350 with D60 front and 10.25 rear? I know I probably have the 10.25 1st gen and the 93 has 2nd gen. Are the parts interchangeable? What about the front D60's, are they the same?
Thanks
Old 09-10-2012, 03:18 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Ford4Life7.3 is offline
I know they can be swapped, but ive never done it so dont know the details. I believe they are a direct swap
Old 09-10-2012, 05:48 PM
tecgod13's Avatar
tecgod13
tecgod13 is offline
Front should be no problem, I'm pretty sure the middle stayed the same, just went from kingpins to balljoints and even the hubs should be the same anyways.
In the rear, I think there were some differences with the pinion design, not entirely sure what that entailed... You might need to swap the driveline yoke to match the pinion. And there may be a difference in spacers or pinion bearings. The ring should be fine though.
Hopefully someone more knowledgeable chimes in.
Old 09-10-2012, 05:59 PM
91dirtydiesel's Avatar
91dirtydiesel
91dirtydiesel is offline
In my 91 I'm running the newer 97 10.25 rear end. Worked just fine, no yoke, pinion, or driveshaft issues.
Old 09-10-2012, 06:00 PM
Johnny L's Avatar
Johnny L
Johnny L is offline
cool. thanks guys
Old 09-10-2012, 07:58 PM
bashby's Avatar
bashby
bashby is offline
There are short and long pinion 10.25's. I'm not sure of the year when they changed.
Old 09-10-2012, 08:35 PM
Johnny L's Avatar
Johnny L
Johnny L is offline
True. But do they have the same housing so if the pinion and bearings are swapped also it would fit?
Old 09-10-2012, 08:36 PM
bashby's Avatar
bashby
bashby is offline
Pretty sure housings are different.
Old 09-10-2012, 08:38 PM
bashby's Avatar
bashby
bashby is offline
Just look up ring and pinions for a 10.25, it should be pretty easy to find the year break. I think it was before both of your trucks.
Old 09-10-2012, 08:45 PM
bashby's Avatar
bashby
bashby is offline
Old 09-10-2012, 08:58 PM
Johnny L's Avatar
Johnny L
Johnny L is offline
Thanks a lot! So they do have the same housing, you just need to keep the yoke matching the pinion (long/short).
Old 09-10-2012, 09:51 PM
300-6 AUTO TECH's Avatar
300-6 AUTO TECH
300-6 AUTO TECH is offline
The original owner of my '94 F350 did this (swapped in 4.10's). It didn't have enough power when pulling. In my opinion, I would have rather improved the engine performance so that the 3.55's didn't hinder the performance and keep the nice highway RPM. What I want to do with it now is work back the other way and improve the engine performance and someday go back to taller gears so that I can run down the highway at an economic RPM. I don't like the 4.10's. That's me though.
Old 09-10-2012, 11:36 PM
Johnny L's Avatar
Johnny L
Johnny L is offline
Thanks for the input. I have an ats turbo that i am waiting for time to install. I think i will get that in and decide if if the extra torque leaves me happy enough with 3.55's. I dont ever tow so it's not such a big deal. Its also nice highway cruising at 1800 rpm
redxl1664
11-30-2017 09:11 PM
GNR22
09-10-2012 09:54 PM
Harvester93
07-12-2012 01:01 AM
Johnlwlr
1999 to 2016 Super Duty
04-21-2011 09:36 AM
89ford73
07-18-2010 11:56 AM
Quick Reply: 10.25 gears interchangeable?
