Recommend A/C Repair in Fort Worth
Hi all. I have a 1989 F150 with an R12 air conditioning system. It blows air, but the air is not cold. I want to try to get it serviced, not replaced with a new system. I found one shop called Christian Brothers near Hulen Mall which is supposed to work on R12 systems. They are only open M-F. I have not heard anyone speak of them before, so I have no idea if they do good work for a fair price or not. Any recommendations for shops in Fort Worth that could do a good job for a fair price?
Thanks. : )
Thanks. : )
Thank you for the info, Sam. : )
You can convert to R134A cheaper, It will be just as cold when done right. All it requires is some new O-ring seals, new oil, new Drier and a good vacuum and your fixed up. Most this can be done with basic hand tools. Just have someone pull your vacuum for 30 mins then fill with R-134A. Do not use any of that sealer crap, it screws your cold air temps up.
designbc
09-23-2003 01:06 PM
