1978 - 1996 Big Bronco
Squeak
Old May 15, 2003 | 03:02 PM
screwy's Avatar
screwy
Squeak
For some time now my engines had a squeak squeak squeak noise that changes with the RPM's. I replaced the belt, idle pulley and tension pulley in effort to kill it. its coming from around the alternator but I don’t think that’s it is their anything else on that side that could squeak an emissions valve or something?
P.s. its a metal on metal sound.
Old May 15, 2003 | 03:47 PM
fcarruth's Avatar
fcarruth
Squeak
My smog pump below the alternator was a real screamer. Once replaced, mine calmed down. Don't know, but it could be it. Only cost about $35. from auto parts store and took less than an hour to replace.
Hope this helps,
Old May 15, 2003 | 04:00 PM
screwy's Avatar
screwy
Squeak
That’s what I would have suspected too but my truck doesn't have a smog pump. thanks anyway
Old May 15, 2003 | 06:05 PM
greystreak92's Avatar
greystreak92
Squeak
How about serpentine belt idler pulley. Mine chirps every time the humidity gets above about 60%.
Old May 15, 2003 | 06:36 PM
screwy's Avatar
screwy
Squeak
Changed them already
Old May 15, 2003 | 08:02 PM
steve83's Avatar
steve83
Squeak
Take the fan clutch off and see if it stops. Try shooting some Liquid Wrench into the bottom of the distributor (inside the cap). If you get desperate, just take the whole belt off and see if it still makes the noise (don't run it too long ).
Old May 15, 2003 | 10:13 PM
BOJOFASO's Avatar
BOJOFASO
Squeak
i to had this annoying squeak. it turned out to be the fan clutch.does it do it when the engine is cold?when my truck WAS NOT running i could turn the fan by hand and i could hear the squeak.also when the engine was hot and i turned it off i could here the squeak for maybe 1 second until the fan stopped spinning. good luck
Old May 15, 2003 | 10:17 PM
screwy's Avatar
screwy
Squeak
thanks steave I'll try those when I get time. It doesn't change when I hear the fan speed up but I will try it anyway.
