"D'oh!"
Old Sep 7, 2012 | 09:28 PM
cstock's Avatar
cstock
"D'oh!"
Replaced an injector on 7.3 powerstroke today and was ready to button it up, then..... the 10mm socket I had just used to tighten glow plug fell in hole by injector. I had shop towels stuffed everywhere I though but I missed one lousy place(it was #7 so kind of a pain) then Murphy's law took over. I could see it for a minute with flashlight and mirror but it fell to who's knows where when I almost had it with my claws grapper. Now what? if I leave it will it block an oil port or more? If I can't leave it how much do I have to dissemble to get to it. I'm sure you pro's on this site get a few laugh's out us amateurs but I need help thanks
Old Sep 7, 2012 | 09:32 PM
snakedoc's Avatar
snakedoc
was it the hole on the bottom of the heads? i think there is where the oil goes back to the oil pan. i think it is there and should not harm a thing.
JT250's Avatar
JT250
I had something fall in a pushrod home the other day. I fished it out with a magnet. Even if you can't see it get a magnet on a string or on of the extendable type and go fishing.
Old Sep 7, 2012 | 09:33 PM
CSIPSD's Avatar
CSIPSD
More then likely it fell down to the pan...
Old Sep 7, 2012 | 09:48 PM
cstock's Avatar
cstock
no, it's at the top, "v" shaped port that push rod passes through before entering cylinder head (for injector to right of the one I just replaced.)
Old Sep 7, 2012 | 09:50 PM
cstock's Avatar
cstock
I tried a magnet a few times, but don't know which way it went
Old Sep 7, 2012 | 09:52 PM
cstock's Avatar
cstock
So there's room for a deep 10MM socket to fall to oil pan? If true I hope it did, thanks, Charlie
Old Sep 7, 2012 | 09:53 PM
snakedoc's Avatar
snakedoc
it most likely will make it to the pan.
cstock's Avatar
cstock
would that be the pushrod home?
Old Sep 7, 2012 | 10:05 PM
cstock's Avatar
cstock
Old Sep 8, 2012 | 12:03 AM
BigAlsPSD's Avatar
BigAlsPSD
If you are talking about the somewhat VEE shaped holes above the injector bores, then yes those are the holes where the pushrods are.
Old Sep 8, 2012 | 12:28 AM
cstock's Avatar
cstock
yea I know but does it matter if there is a 10mm socket in there too?
Old Sep 8, 2012 | 01:27 AM
BigAlsPSD's Avatar
BigAlsPSD
Personally I wouldn't like knowing. I would try to retrieve it with a magnet personally.
Old Sep 8, 2012 | 02:14 AM
Brant Bowrifle's Avatar
Brant Bowrifle
Had something similar happen to a different engine. I tried using the magnet on a string but I couldn't get much range of search down there so I bought and attached a strong little magnet to a piece of wire and kept changing the bend until I caught my fish. To keep it from sticking to the block I pushed a rubber cap I had onto the contact end, leaving enough magnet exposed to get the fish. Good luck.
Old Sep 8, 2012 | 01:06 PM
cstock's Avatar
cstock
yea I went to buy another 10mm socket and seen this hi powered magnet attached to a flexible wire tool. Stuck it down hole about 6" and got it, thanks for help.
