Flex plate replacement
Old 03-26-2014, 01:36 PM
'06Roush_150's Avatar
'06Roush_150
'06Roush_150 is offline
I've called a couple shops to get quotes to have my flex plate changed. One shop said they would have to lower the engine a few inches to get the tranny out easier. From what I can see this is not needed. Anyone with experience on this know if dropping the engine is needed? Thanks.
Old 03-27-2014, 11:05 AM
'06Roush_150
Anyone?
I don't believe nobody has pulled a tranny out if these trucks. I'm trying to get my truck to the shop tomorrow, so any input would be appreciated. Thanks again.
Old 03-27-2014, 12:01 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
They don't need to lower the engine, just tilt it back a little to get to the top bellhousing bolts. They shouldn't charge extra for that.
Old 03-27-2014, 01:06 PM
'06Roush_150
Even that seems unnecessary. Can't you get those top bolts with a long extension. I appreciate the replys.
Old 03-27-2014, 07:06 PM
ojai150's Avatar
ojai150
ojai150 is offline
Yes you can , with enough extensions , and flex joints, I'm sure you can do it , let us know how that goes , OR you could take off the crossmember , and when it naturally tilts down a little , you can take it off , I'm sorry , but why ask a question, then 2nd guess the person ? (just wondering )
Old 03-27-2014, 07:44 PM
'06Roush_150
Its called getting another opinion.... do you have to loosen the motor mounts? Disconnect the radiator hoses? How bout the fan shroud? Any electrical you would have to worry about? Just seems slapping a couple extensions together would be quicker.
Old 03-27-2014, 11:00 PM
ojai150's Avatar
ojai150
ojai150 is offline
Well 70f100longbed , has 840 posts , and is very knowledgable with Fords,
In cases like this youtube is your friend just search for a video on removing a transmission from a ford pickup,..
Old 03-28-2014, 06:08 AM
TallEddie1981's Avatar
TallEddie1981
TallEddie1981 is offline
The quicker way is not always the smartest way. Don't forget, as you add extensions and universal joints you reduce the amount of torque being transferred from the ratchet to the bolt. This will make it harder to loosen the bolt. Also, you are increasing the chances of the socket twisting and slipping off the bolt and rounding it off. Good luck getting it out then.
Old 04-12-2014, 12:52 PM
'06Roush_150
Well I'm stuck. My truck is supercharhed and in order to drop the engine enough, it looks like I need to remove the supercharger because it is hitting the firewall. I called the stealership and the said they would lift the cab!! I guess my question is, is the metal gasket between the supercharger and intake reusable? And if anyone has a better idea let me know! Thanks again.
Old 04-12-2014, 11:09 PM
'06Roush_150
Nothing..?
Old 04-13-2014, 12:29 AM
ojai150's Avatar
ojai150
ojai150 is offline
Nothing..?
I think you should ask for a second opinion,...
Old 04-13-2014, 06:56 AM
danorules's Avatar
danorules
danorules is offline
I am not familiar with the super charger gasket replacement, if it was me I never reuse. I find the extra few $ gives me piece if mind.
As far as lifting the cab, that is a fairly common practice now. I have seen many trucks that need this for different repairs. The cab doesn't need to be removed,just tilted. You loosen the body mount bolts and Jack the body up enough to give you room
Good luck
Old 04-13-2014, 11:13 PM
'06Roush_150
Thanks danorules...I guess I just have to decide what will be less work now, lifting the cab, or removing the blower.
Old 04-14-2014, 01:15 AM
ojai150's Avatar
ojai150
ojai150 is offline
Have you actually gotten your head under the hood and looked at it closely?
Old 04-14-2014, 01:18 AM
'06Roush_150
No...what's a hood??
Quick Reply: Flex plate replacement
