Windsheild Wipers??
Old Sep 7, 2012 | 02:17 PM
Supercab's Avatar
Supercab
Wink Windsheild Wipers??
-About 4 years ago I replaced some el-cheapo blades the po had put on my truck with BOSCH ICONs.
-Back then there was a thread on wipers going on and most folks really liked the Icons.
-There was some talk about going from the standard 20" blades to 22"
-Today I went and bought anouther set of Icons and acording to the book it says '99-'08 use the 20" and '09-'12 use the 22" I am under the impression that all SuperDuties from '99 to present use the same windsheild, and would think then that they use the same wiper arm.
-I was going to get the 21" just to try them, but got cocky and got the 22"s-I haven't installed them yet.......anyone have any advise or experiance to share with installing bigger wipers than the factory calls for?? Thanks!
Old Sep 7, 2012 | 02:21 PM
carltonwebb's Avatar
carltonwebb
I have run 22s in several brands. no issues.
Old Sep 7, 2012 | 03:10 PM
Supercab's Avatar
Supercab
Great! Thanks! I feel the more clear area the better during a real rain...
Old Sep 7, 2012 | 04:15 PM
BadDogKuzz's Avatar
BadDogKuzz
I have been running over sized blades on most of my vehicles for a couple years now. And on my truck I see no ill effects until winter hits. Then I have problems with the blades not creating enought down force to keep the snow and ice clear. I do believe that it is because the wiper arm/ springs only create so much down force. Then once you spread that down force out another 2 inchs there is less force per inch. So I am going back to the stock size on my truck.
Or maybe I just need to get a new wiper arms. But wiper blades are cheaper and I change mine about once a year anyway.
Old Sep 7, 2012 | 04:32 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Any difference in the motor that moves them?
Old Sep 7, 2012 | 05:05 PM
Franko72's Avatar
Franko72
Molon Labe
On some vehicles Like my old '94 Z28 you had to run the correct size or smaller because of the contour of the windshield. (One size up and the ends of the blades wouldn't touch the glass)
Our trucks have a pretty flat windshield, You can go one or two sizes up without issue.
Old Sep 7, 2012 | 05:10 PM
binuya's Avatar
binuya
I think there's something to what you are saying about the longer blades 'floating' more on the windshield. I ran 22" a couple years ago and had a spot to the far left of the windshield that wouldn't clear well. In a windy downpour it would get worse. When I went back to the 20" they cleared perfectly in all conditions and perfomed better over all. Same brand and model of blade. (The Goodyear blades at Costco)
Old Sep 7, 2012 | 05:12 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I'm running 26" blades but the passenger side doesnt touch when at rest. I'll go with 24" next time.
Old Sep 7, 2012 | 05:26 PM
Supercab's Avatar
Supercab
Wink
NO offense, but are you sure you have 26" blades on your truck?? that seems awfully big to me.....
Old Sep 7, 2012 | 05:28 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yes. I'm sure. Like I said, next time 24".
SuperDuty Quick Tip: Plus Sized Windshield Wipers - YouTube
Old Sep 7, 2012 | 05:29 PM
Supercab's Avatar
Supercab
Wink
-Theres our friend Frank. Glad to see/hear that you are "home" safe!
-I think I'm going to put the 22" on mine.....if they work on the '09-'12s they'll work on my '99..............Love the EXPENSIVE Bosch Icons though....they lasted 4 years in the Florida heat & rainey seasons, plus 1 icey cold trip to Ohio last winter......
Old Sep 7, 2012 | 05:43 PM
Franko72's Avatar
Franko72
Molon Labe
I lasted 30+ cold winters in Ohio myself.... It's good to be home.
Old Sep 7, 2012 | 05:53 PM
Poolguy601's Avatar
Poolguy601
Motors are the same. I run the 22's
Old Sep 7, 2012 | 08:18 PM
Pitcrw6's Avatar
Pitcrw6
You can go up to 26 in but the tips have a hard time touching the windshield and when driving the wind will blow them up a little because there's not enough of hold pressure on the tips. I just bought some 22 in rain x blades because they were out of 24 in ones.
Old Sep 8, 2012 | 11:17 AM
Supercab's Avatar
Supercab
Sooo...I'm good in installing the 22"s then.....thats what they are using from the factory on the '09-'12s....same windsheild......hopefully the same wiper arm.....
-I sure don't want any trouble here in Fl because we do have a pretty bad rainy season each year and winds and of course an occasional Hurricane.....
