Sponsored by: Real Truck
Transmission upgrade?
Old Sep 16, 2012 | 07:46 PM
WoodRacing's Avatar
WoodRacing
BTS is $3200.00 for just the trans that does not include shipping.
Monster is $2584 and includes the trans, torque converter, and shipping, and it comes with a 3 year warranty.
I think the BTS is probably the way to go for a 1000 ft lb powerstroke since these are the only transmissions they build. They seem to know what they are doing. But my truck has a stock 5.4 gas engine I just need a transmission that will hold up to towing 3000 lbs every day.
I would probably have $4000 or more in a BTS by the time I bought there torque converter and had it shipped.
Old Sep 16, 2012 | 07:50 PM
Rubenk's Avatar
Rubenk
Those BTS numbers sound about right.
But there is a certain value to the builder daring you to break it and guaranteeing to fix it if you do.
Old Sep 16, 2012 | 08:12 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I would run the Monster. BTS is my primary pick...but the prices dictate the choice IMO
Old Sep 16, 2012 | 08:45 PM
WoodRacing's Avatar
WoodRacing
I agree with you Rubenk there is value in that. I just think it's really more than I need if my truck was a powerstroke I would consider it.
Old Sep 17, 2012 | 07:02 PM
BobbyDiesel71's Avatar
BobbyDiesel71
please consider a valve-body upgrade like a Transgo Tugger II kit included in your Monster rebuid trans
I think BTS includes an improved valve body design
Old Sep 17, 2012 | 08:35 PM
Pitcrw6's Avatar
Pitcrw6
But BTS is lifetime warranty Monster is only 3 yrs. Huge difference.
Old Sep 19, 2012 | 03:43 PM
WoodRacing's Avatar
WoodRacing
I didnt realize BTS had a lifetime warranty? I might have to call them. They are way out of the amount I want to spend on this truck though.
Old Sep 19, 2012 | 03:44 PM
WoodRacing's Avatar
WoodRacing
I will check into it. Thanks
Old Sep 19, 2012 | 05:14 PM
redford's Avatar
redford
FTE Leadership Emeritus
Originally Posted by AGE mechanic
I guess there could be something wrong that didn't require a rebuild. Getting into the hypothetical now though.
That was kind of where I was heading. If it is something simple, a rebuild is a waste of money.
Old Sep 19, 2012 | 06:57 PM
SuperDutyScaler's Avatar
SuperDutyScaler
did you check your feed bolts in your trans yet? They are know to come loose or fall out and cause a no forward gears or a loss of one or more forward gears....
Old Sep 19, 2012 | 08:48 PM
meborder's Avatar
meborder
I'm wondering what conditions caused the trans to fail with such a light load. Seriously, with only 3K behind you, that truck shouldn't even bat an eye.
My opinion .... worth the price you pay ... any stock reman would be more than adequate. Not sure how many miles you had on the trans before it failed, but you should be able to get at least that much again out of just a stock reman.
Old Sep 19, 2012 | 09:10 PM
shadows4's Avatar
shadows4
Doesn't Ford offer a re-manufactured HD tranny for around $2500? Thought I read that some where.
Old Sep 20, 2012 | 12:57 AM
  #28
Pitcrw6's Avatar
Pitcrw6
yes.......
Old Sep 20, 2012 | 10:51 AM
  #29
BadDogKuzz's Avatar
BadDogKuzz
I agree I would start there. It is a common problem and it is offen over looked.
WoodRacing But if you go to get a reman or have it rebuild don't use a local builder because 9 out of 10 don't have a clue on what makes a 4R100 work more or less what the weak links are in them. So if you don't want to drop the coin on a JW or BTS the only other trans I would use is the Ford reman HD. And Monster trans I don't know if they do the center support mod or if they do some of the other modds needed in a 4R100. I think they just reman to stock which isn't good.
Old Sep 21, 2012 | 03:23 AM
  #30
WoodRacing's Avatar
WoodRacing
I'm assuming the feed bolts are in the valve body somewhere I can check them but the fluid is brown and smells burnt. I'm pretty sure it's done.
