Sponsored by: Kumho
Steering stabilizer
Old May 15, 2003 | 09:25 AM
benman's Avatar
benman
Steering stabilizer
I hit a skunk this past weekend and bent the steering stabilizer shock on my 2002 F350. Now the steering feels sticky when I turn to the right so I plan on removing the thing. Any thoughts on whether I should replace it or just go without?
Old May 15, 2003 | 10:39 AM
Blue96
Guest
Posts: n/a
Steering stabilizer
Try it with out it.
Your steering will wander a bit more than your use to. But after a while you may not even notice that its missing.
If its hard to get used to get yourself a replacement. As the shock should only put you back less than 50 bucks.
Good Luck.
Old May 15, 2003 | 12:51 PM
beartracks's Avatar
beartracks
Steering stabilizer
Geesh! That must of been some skunk! There are some things I would pay to have done for be.
greenpus's Avatar
greenpus
Steering stabilizer
I would pay to have someone else fix it because that part probably has skunk juice on it and it will stink you up something bad.
Old May 16, 2003 | 09:44 AM
benman's Avatar
benman
Steering stabilizer
Well, I took it off and haven't noticed a difference (except that the steering no longer sticks). I'll probably replace it since I think it's covered under roadhazard insurance. It's $50 for a new shock through Ford so no biggy.
It had a big tail and I was told it was most likely a skunk. No carnage to prove it though as the truck is spotless.
Thanks for the input,
Ben
Old May 16, 2003 | 04:13 PM
MustangGT221's Avatar
MustangGT221
Steering stabilizer
You can go with a quality stabilizer from skyjacker or rancho for less then $50 bucks.
