6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Regret!
Old Sep 6, 2012 | 07:59 PM
wp6529's Avatar
wp6529
Originally Posted by ljutic ss
When your checking the coolant nitrite levels, any reading from 0-300ppm would require adding 2 pints of Motorcraft vc-9 any reading around 500ppm would require only about 12 oz. of vc-9 finally a reading of around 800ppm would only require 6 oz of vc-9. The ideal nitrite condition is 1200ppm and all the above data is taken from Wix filtration corp. and the additive amounts are based on the 6.4 coolant capacity.
VC-9 is the Iron Remover cleaner that is used in the cooling system flush process.
VC-8 is the Cooling system additive to restore nitrite levels.
A reading above 800ppm is considered acceptable.
Between 300ppm and 800ppm you need to add two bottles of VC-8 to
Below 300ppm requires a full cooling system flush with VC-9 and refill with fresh Ford gold coolant.
This is from the Ford diesel supplement.
onug
2015 - 2020 F150
42
Dec 6, 2019 05:48 PM
Brown Dog
Apr 30, 2017 06:04 PM
sand_fiend
Jun 21, 2011 08:49 PM
mprice
Oil & Lubrication
Jul 14, 2010 09:30 AM
884x4broncoII
Feb 16, 2008 10:42 AM
