2004 6.0
Old Sep 5, 2012 | 07:06 PM
alexisvfd's Avatar
alexisvfd
2004 6.0
i have a 2004 f250 6.0 and monday i left the house got aprox. 5 miles and it just shut down..i thought it was bad fuel but ive drained the tank and lines and it still wont do anything..it cranks every once and a while but i only runs for 2 secs if that...my buddy said maybe its the power pack.. yall have any ideas or things i can try....thanks
Old Sep 5, 2012 | 07:36 PM
BLADE35's Avatar
BLADE35
is there fuel in the Upper Filter housing?????
do you have any gauges?????
Old Sep 5, 2012 | 07:42 PM
alexisvfd's Avatar
alexisvfd
there is fuel and i can unhook the lines to the fuel filter on the motor and cut the key to on and fuel pumps out...so that eliminates the pump and the fuel is brand new and good...it cranks bout every 10 tries but only runs for maybe 2 seconds and dies..idk im lost..idk what else to do
Old Sep 5, 2012 | 08:01 PM
BLADE35's Avatar
BLADE35
unplug ICP sensor and try to start it
Old Sep 5, 2012 | 08:13 PM
alexisvfd's Avatar
alexisvfd
wheres the icp sensor...if i do that what will it do..inform me what is is there for and what it does
Old Sep 5, 2012 | 08:56 PM
daddykitty's Avatar
daddykitty
benny does unplugging the icp sensor give a default to the pcm to fire the injectors or are the injectors controlled my the ficm logic power?
Old Sep 5, 2012 | 09:16 PM
BLADE35's Avatar
BLADE35
ICP either in the Passengerside valve cover or under turbo
if it will start ICP unpluged the ICP sensor is bad
you need some gauges
Loftatsea
Apr 21, 2019 01:07 PM
coloradojeep1
Nov 23, 2017 06:57 PM
Mamacaldera
Jun 11, 2017 04:38 PM
daddy23
Jul 22, 2013 08:50 PM
djhecker15
Aug 4, 2011 09:19 AM
