engine bolt
Old May 15, 2003 | 08:21 AM
big88b2's Avatar
big88b2
engine bolt
will the V8 (302 or 351) engine bolts fit in the inline 6's . i have the 4.9 but it blew up a couple days ago.
Old May 15, 2003 | 09:24 AM
millertime300's Avatar
millertime300
engine bolt
The bolt pattern is the same, but the bolt lengths could be a little different, but I doubt it.
Old May 15, 2003 | 09:25 AM
millertime300
engine bolt
The motor mounts are what you need to worry about. I can't tell you if they are the same, but you might even need diferent perches. Try the archieves.
Old May 15, 2003 | 06:20 PM
steve83's Avatar
steve83
engine bolt
The perches are different, and so is the radiator, Y-pipe, & engine compartment wiring harness.
