Need help indentify 9 inch rear
Old May 14, 2003 | 11:32 PM
boone6978's Avatar
boone6978
here is what the tag says
WOM-AC 4JB
3 25 9 33/B
can anyone tell me what year this is from and what splines it has? Thanks Dan.
Old May 15, 2003 | 08:56 AM
LxMan1's Avatar
LxMan1
Sorry. All that I can tell you is that it is a 3.25 open(non-posi) 9" rearend.
Jimmy
Old May 15, 2003 | 09:29 AM
millertime300's Avatar
millertime300
Take off a rear tire(5 bolts), brake drum (might need a good beating), remove the brake backing plat bolts (4).
There is a hole on the face of the axel that you have to spin to line up with these bolts.
Pull on the axel, count the spline and put it back together. Total time 10-15 minutes tops.
Trust me it is very easy. You should have 28 or 31 splines.
