Right. Since the spout circut seems to be only one wire not connected to anything else than the PCM I was going to cut the wire at the spout connector and at the PCM and run another wire for testing purposes. If there are problems after that I am going to pull the PCM and look for internal circut damage.
Fixed. I replaced the wire from the spout connector to the pcm. No more backfires, no more stumbling. And the wire from the spout connector to the PCM is one straight wire. It doesn't connect to anything else.
