1995 Ford Aerostar
1995 Ford Aerostar
I am at my wits end with this.. It has a flexplate/flywheel issue... its a 4.0 automatic and have replaced it now twice... teeth keep getting broken off... have bought aftermarket and one from Ford Dealer and both have same issue... we shimmed the started on one and not on other and again teeth broke off... Does anyone have any suggestions or where I can maybe find an answer... thank you
1995 Ford Aerostar
On the first one that was changed there was no damage at all to the bendix but we replaced the flexplate and starter and it did ok the first few starts then started grinding again.. and now it will not start at all just grinds. will take this starter out an look but the first one had no damage just the teeth broken off flexplate
I bought the van for 500. knew it had to have the flexplate changed so replaced it along with a new starter.. that was with the aftermarket flexplate.. lasted for about 3 months then started grinding again and got to where wouldn't start.. So went to Ford dealer bought the dealer flexplate again with another Starter and this time did the relay... and still the same issue and not its where it won't start just grinds.. appreciate any help , ideas
Usually the bendix is pushed out by the large solenoid on the side of the starter. It can stick when they get old and their lubricants harden due to dis-use. That's not likely with your new starter. The solenoid has a separate smaller wire that powers it when the key is turned to the crank position. If that wire is not de-energizing, it will push the starter gear out. But if that gear is always engaged to the flywheel, the starter will make screeching or howling noises when the engine speed gets beyond idle.
I'm wondering if the starter mount or bell housing has sustained damage that's causing mis-alignment of the starter?
starter out of align with flexplate
starter bendix not extending completely
bendix teeth damaged.
starter shaft bent
flexplate teeth damaged.
starter bendix shaft not the correct spec'd length, not the correct starter
starter shaft bent
