General Diesel Discussion
Idea for a unique engine swap!
Old Aug 31, 2012 | 02:02 PM
'97f2507.3LBEAST's Avatar
'97f2507.3LBEAST
ok so today after fixing a problem i had from last night, i started thinking about possibly swapping out the 7.3L in my '97 f250, for somthing a little bit stronger and more reliable.
Hence. . .
Caterpillar C7.1 ACCERT diesel swap! the C7.1 is a 7L (427.7cu in.) inline 6 turbo diesel. so its about the same size and weight as the 7.3L V8 diesel.
its rated at 275hp @2200rpm, and 927lb ft @1400rpm. but i plan on upgrading this motor quite a bit. It is aftercooled already so i dont need to worry about that.
but yeah thats my idea, if you would like to see the engines dyno sheet, let me know and i can email you the entire dyno sheet, along with the info spreadsheet as well.
Old Aug 31, 2012 | 04:21 PM
'97f2507.3LBEAST
ok quick question for anyone that knows! how can i upload the dyno results to the forums for people to see?
that would be easier than emailing the dyno results to a whole bunch of different people that are interested.
Old Aug 31, 2012 | 06:20 PM
tjc transport's Avatar
tjc transport
i ain't rite
that engine is too big to fit in your engine bay.
if i remember correctly, you would need to put something like 6 inch body lift on to fit it in.
Old Aug 31, 2012 | 10:09 PM
'97f2507.3LBEAST
oh. . . are you sure cuz i have the dimensions of the engine right here and i think it would fit. http://www.cat.com/cda/files/2525170/7/LEHH0006.pdf
its actually not as big as you might think. either that or my measurments of my own trucks engine bay are waaaaaayy off!! lol.
all the engines dyno information is on that page as well.
and if this engine wont fit, the next step down would be the C6.6 ACERT. which actually would fit!
Old Sep 1, 2012 | 08:16 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You have big dreams. I don't see how that engine will fit. The turbo will have to be moved and the oil pan will drag on the ground to get the fan in the right place.
You have the best engine in the truck now. Do some mods to it and get around 400 HP. Would be a lot cheaper.
What ever you do, we need pics.
Old Sep 1, 2012 | 09:57 AM
TheTowingCowboy's Avatar
TheTowingCowboy
From experience only the only CAT engine I ever seen in a truck was a CAT 3408 from a service truck, stuffed in a 77 Chevy K30, which the guy used a SAE5 spd witha dodge divroced transfercase to run his front axle. He had to put 3 inch of body lift on the truck. And the only inlines you will get to fit in out trucks are Cummins, and some Detroits (The 52 series)
Old Sep 1, 2012 | 10:29 AM
nevrenufhp's Avatar
nevrenufhp
I think you mean a Cat 3208, because a 3408 weighs about 3k pounds. A 3126/C7 will fit. They are actually pretty small for being a 7 litre diesel.
Old Sep 1, 2012 | 10:40 AM
TheTowingCowboy
3208, sorry was thinking about a 3406 at the same time lol
Old Sep 1, 2012 | 06:51 PM
'97f2507.3LBEAST
well i have pics on the way, because i did the swap, and it fits!!!!!!!! which was soooo cool today when we got it in!!!! but yeah i have picks on the way!!!!
Old Sep 1, 2012 | 08:21 PM
1960fordf350's Avatar
1960fordf350
Guy over in Greenville Pa has a 3-53 Detroit stuffed in a 79 Bronco. Interesting conversion. He also has a Dietz diesel stuffed in an F100. Funny seeing it run with no radiator
Old Sep 1, 2012 | 08:47 PM
TheTowingCowboy
Lol Deutz diesels are the ****! Got one of those odd two cylinder jobbers in our Belarus 250AS
Old Aug 22, 2014 | 03:17 PM
andrewhpaul's Avatar
andrewhpaul
great! lets see the pics. I am also considering the same swap and would love to know how you did and some other info
Old Sep 2, 2014 | 12:09 PM
85F350IDI's Avatar
85F350IDI
Did you ever get the pics? @97F250
Jmann98
2009 - 2014 F150
Sep 21, 2016 09:05 AM
dwingalls
Engine Swaps
Nov 23, 2013 04:13 AM
mrblonde108
Mar 9, 2011 06:00 AM
logan horse
Feb 11, 2010 11:23 AM
Pablo-UA
Aerostar
26
Feb 13, 2008 08:24 PM
