2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
KR Illuminated Door Sills
Old 08-30-2012, 02:02 PM
rexster314's Avatar
rexster314
rexster314 is offline
I received the Ford door sills yesterday that I had won off Ebay. They were brand new in the box, and had everything but instructions. Since Ford recommends a dealer installation, that's probably why there were none. Not to be outdone, I posted on the12volt.com asking where the dome light wire(s) were. I wanted the sills to light upon entry and turn off when the dome lights went off (theater lighting). Flobee4 on 12volt answered my question within an hour with exactly what I was looking for. Several months ago I had also ordered some mini LED's from Oznium with intentions of putting them in my console cupholders, but never got around to it. I still haven't done that, but I used 3 of them for footwell lights off the same circuit. I put one led in the driver's footwell and two on the passenger side. I've labeled the images so they should be self explanatory. Next time I'm doing the console lighting. I'll also post some night pics of the door sills later
Old 08-30-2012, 06:51 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
Look Great !!!
Matt
Old 08-30-2012, 07:48 PM
Expypate's Avatar
Expypate
Expypate is offline
I've been planning to order a set for my Expy also. Can you tell me what color the dome light harness wires are? It looks like they were behind the kick panels.
Old 08-30-2012, 07:52 PM
rexster314's Avatar
rexster314
Both of these are Positive polarity and located at the SJB in the passenger kick Panel
Dome Lights: Gray/purple - Gray 14 pin plug(A)- pin 9
Puddle Lamps: Purple - Gray 26 pin plug(C) - Pin 12
Puddle lights won't come on if the car is running and a door is opened.
I used the gray/purple dome light wire since I wanted them to go on and off with the dome lights
Old 08-30-2012, 08:18 PM
Expypate's Avatar
Expypate
Expypate is offline
Excellent. Thanks for the info. I knew I could figure it out, but it's nice to know what you're getting into before getting started. (especially on a brand new truck)
I guess I have no excuse not to get mine on order!
Old 08-30-2012, 08:40 PM
rexster314's Avatar
rexster314
From start to finish was about 3 hours. I really took my time and kept to the saying "Measure twice, cut once". If I did it again could probably do it in about an hour and a half.
Old 08-30-2012, 08:49 PM
Expypate's Avatar
Expypate
Expypate is offline
Live anywhere near NY?
Old 08-30-2012, 09:08 PM
rexster314's Avatar
rexster314
Hah! Texas gulf coast!!
Old 08-30-2012, 09:09 PM
rexster314's Avatar
rexster314
Here's one I just took at night
Old 08-30-2012, 09:20 PM
Expypate's Avatar
Expypate
Expypate is offline
Looks sweet at night. Placing my order now!
Old 08-30-2012, 09:59 PM
rexster314's Avatar
rexster314
If you need any more help/info message me
Old 08-31-2012, 09:20 AM
pgonza2723's Avatar
pgonza2723
pgonza2723 is offline
I was actually wanting to do this as well for the foot wells. What wiring do I need to hook into for the dome light action as well under the dash?
Old 08-31-2012, 09:26 AM
rexster314's Avatar
rexster314
Not sure cause yours is 4 years older than mine, but on mine it was the purple/gray wire coming out of the power box behind the passenger kick panel. I got my leds from Oznium. Already has a resistor in place, prewired, all you have to do is connect pos. and neg and you're there
Old 09-01-2012, 01:48 AM
5.4T's Avatar
5.4T
5.4T is offline
I want some!!!
Old 09-01-2012, 10:15 AM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
pgonza2723,
The dome light wiring in your 2008 is the same as rexster314 posted.
SJB - Gray/purple wire - Gray 14 pin plug(A)- pin 9
Matt
Poonbag
2009 - 2014 F150
21
12-28-2016 10:52 PM
cameeks
Texas Chapter
12-08-2013 09:37 AM
mikey350
6.7L Power Stroke Diesel
27
04-16-2013 07:59 AM
bgalaxy67
Aftermarket Products
22
02-10-2013 11:14 AM
Ford Fx4
2004 - 2008 F150
05-05-2009 04:34 PM
Quick Reply: KR Illuminated Door Sills
