2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
brake caliper bolt size
Old 08-02-2010, 12:59 PM
00excursion's Avatar
00excursion
00excursion is offline
Before I tear into my brakes and realize I don't have the right tool, does anyone happen to know what is needed to loosen the caliper bolts on 07 expedition? I've gotten conflicting details as to hex or torx and size, any details would be appreciated.
Old 08-03-2010, 08:51 PM
07shelby's Avatar
07shelby
07shelby is offline
Just literally got back inside tonight after doing my 08 Expedition brakes.
The caliper pin bolts are an allen(hex) head that is 9mm. Its not a torx
Most hardware stores may not have a 9mm on the shelf, usually the sets
have an 8mm and then a 10mm...but no 9mm.
There out there..snap on and such...just get it before you jack her up to do the job
Old 08-04-2010, 04:44 PM
00excursion
Thanks for the details, greatly appreciate it!
Old 08-05-2010, 02:37 PM
07shelby's Avatar
07shelby
07shelby is offline
Glad to help. Doing the rear brakes tonight.
Old 08-10-2010, 06:35 PM
dturnersr's Avatar
dturnersr
dturnersr is offline
9MM
Yup, I found out the hard way. Got it all up in the air wheels off, tried both metric and standard size...did not have a 9MM. I ground off an extra 3/8 allen to fit...then went and bought the right one
Old 07-15-2012, 12:40 PM
Jaylegger's Avatar
Jaylegger
Jaylegger is offline
Old thread but the info provided though correct is incomplete. As stated the bolt are hex, 9mm hex for front brakes and 7mm for the rears. A torx (dont't recall which size) will fit and grab enough to remove the rear, unsure about the fronts. Valid for 07 navigator anyway.
Old 09-02-2012, 11:38 AM
raynaldthomas's Avatar
raynaldthomas
raynaldthomas is offline
I've tried a 9mm and it was too small. I have a 2008 expedition limited is there any difference between the limited and the other models?
mofoco1
01-07-2017 09:28 AM
BjornF16
11-18-2016 03:17 PM
berry1234
29
11-09-2016 08:36 AM
GoldCo
10-27-2016 04:29 PM
wilsonriverfisher
Escape & Escape Hybrid
06-13-2008 08:17 PM
Quick Reply: brake caliper bolt size
