clicking noise?
Old Aug 30, 2012 | 02:12 PM
68fordf100v8's Avatar
68fordf100v8
clicking noise?
when i turn key it don't do anything i just keep getting a clicking noise coming from driver side was doing this before i bought new starter and solenoid
truck is 87 f150 with 302
Old Aug 30, 2012 | 03:52 PM
Puddy's Avatar
Puddy
I wonder is your key ignition loose? Still get a door chime?
Old Aug 30, 2012 | 03:56 PM
Puddy's Avatar
Puddy
I know it happened to me once or twice, I just disconnected the battery let it sit, and usually fires back up. Thought it was the starter as well, so I bought a new starter, solenoid and battery, then bought the ign switch, hasn't acted up in awhile
Old Aug 30, 2012 | 05:46 PM
68fordf100v8
i still get door chime and the ignition is little bit loose could that be it?
also i had to wiggle a wire for the solenoid before it stopped starting
Old Aug 30, 2012 | 06:05 PM
octaneforce's Avatar
octaneforce
could be dirty connections at the battery. had this happen to me once. the terminals didnt even look that bad. i cleaned them really well and the trucked turned over fine.
Old Aug 30, 2012 | 06:21 PM
68fordf100v8
I've tried that but I'll try one more time
Old Aug 30, 2012 | 07:20 PM
octaneforce
have you tried jumping the solenoid? i know you said you replaced it but new doesnt always mean good.
Old Aug 30, 2012 | 07:54 PM
68fordf100v8
I've tried that too keep getting a clicking noise from driver side
anything on that side come to mind?
Old Aug 30, 2012 | 07:55 PM
octaneforce
im stumped. is this a manual or auto tranny?
Old Aug 30, 2012 | 07:59 PM
68fordf100v8
It's auto trans
thinking it could be the ignition module
not really sure where that would be at this is my first truck newer then 68 so this is really big change
Old Aug 30, 2012 | 09:02 PM
Lead Head's Avatar
Lead Head
Weak Battery.
Bad Battery Connections.
Bad Engine Ground.
Bad positive cable to starter/solenoid.
Start checking all of those for corrosion/loose-ness.
Nothing to do with the TFI module at all if it is not even turning over. The click is the solenoid engaging but nothing turning.
Old Aug 30, 2012 | 09:51 PM
68fordf100v8
Originally Posted by Lead Head
Weak Battery.
Bad Engine Ground.
I've tried everything but positive cable to starter/solenoid
Old Aug 31, 2012 | 01:07 PM
68fordf100v8
I fixed it had short in wires
Old Aug 31, 2012 | 10:23 PM
Puddy's Avatar
Puddy
right on! which wire was it?
sparr0
Aug 14, 2015 10:09 PM
Tirekicker
Jun 5, 2014 09:05 PM
mike L
Dec 25, 2013 04:16 PM
78 F150
18
Apr 12, 2011 11:35 PM
Cerulean
1978 - 1996 Big Bronco
Dec 29, 2006 06:50 PM
