7.3 IP Problem?
Old Aug 30, 2012 | 11:21 AM
MauleOne's Avatar
MauleOne
7.3 IP Problem?
It looks like the gov on my IP is screwing up.
When I try to rev the engine (in neutral) it will only go to 2500 then falls on its face. RPM drops off and the engine surges. It will hold 2500 even under load.
I just replaced the fuel pump with a new on as PM.
I have not tried putting in an electric pump to be sure there is enough fuel at high rpms but it never had this problem before.
The engine sits all winter between operations.
I believe the rated rpm for this engine is 3200. Is that correct?
Thanks
Old Aug 30, 2012 | 02:53 PM
NMB2's Avatar
NMB2
definitely not right. How does it run up to 2500? How many miles on the pump?
Its kind of hard to say. Could be a worn out pump, could be a contaminated pump... did someone mess with the throttle lever adjustment stops?
Old Aug 31, 2012 | 12:38 AM
MauleOne's Avatar
MauleOne
IP
Runs good up to 2500. Even under load. Then falls off. Other engine keeps pulling.
This is part of a boat package with twin 7.3 engines. The pumps arn't that old and mostly the engines are used to troll for salmon.
Really bad fishing this year.
It will be next month before I can get back to the boat and conduct further experiments.
Maybe I will rig up a fuel pressure gauge on both supply and return lines.
Will post results.
Old Sep 1, 2012 | 11:16 AM
vfelix702's Avatar
vfelix702
Pics would be nice
Old Sep 1, 2012 | 03:33 PM
NMB2's Avatar
NMB2
Oh this is marine....you didn't say that.
Is this something that just started happening? Marine pumps are a little different than truck pumps.
Old Sep 2, 2012 | 12:20 AM
MauleOne's Avatar
MauleOne
Marine 7.3
The fuel pump that is on this engine is straight truck. The only thing that isn't would be the exhaust (water cooled) and the heat exchanger.
Other wise this 7.3 came right out of a NAPA catalogue. I have had it for 10 years now.
Any how, like I said, I will try cutting in an electric pump to see if fuel starvation is the problem. If so I will have to change out the fuel pump I just installed. That is a big pita because the water cooled exhaust blocks the fuel pump and will have to come off.
As for pictures, I have some on my IPhone and will see if I can use them. This is borrowed computer.
4x4falcon
Nov 2, 2025 08:43 AM
mark460
Jan 14, 2015 02:18 PM
stewart2000
Jul 25, 2012 11:42 PM
butter1965
Jul 13, 2007 08:48 AM
FORDBONE
Jul 29, 2003 02:20 PM
