Sponsored by: Auxito
brake pad question
Old Aug 28, 2012 | 08:49 PM
cw009's Avatar
cw009
brake pad question
Went and got new tires on the supercrew. Went going through parking lots or simply driving i hear a loud squeal like brake pad squeal. I put brand new wagner ceramics on the truck. Also if i turn to the left the driver side rear sounds like brakes are dragging against the rotor. Whats goin on with this. The squal will happen between 10 mph to 20 mph and the grinding noise will happen if im crusing or turning to the left. It goes away when i apply the brakes. Please help. Thanks a ton.
Old Aug 28, 2012 | 11:19 PM
Bluegrass 7's Avatar
Bluegrass 7
Take the wheels off and look for incorrect assembly.
There is an inner and outer pad and they only go on one way.
The loaded caliper has to set on the upper and lower mount support bar and their stainless steel shim covers.
Maybe a shim is out of place.
Look to see if the discs have rust/wear high rings in the inner and outer surfaces that is not allowing the pads to seat on the disc without wearing in to meet the disc surface.
I'm not trying to insult you but you did the job.
When there is a problem you always go back and look at what you have.
Good luck.
Taylor Minton
2004 - 2008 F150
Aug 12, 2015 07:35 PM
ag-ford-4x4
17
Oct 16, 2014 03:24 PM
mrcrownline
Feb 15, 2013 08:07 PM
LTCPipkin
Mar 9, 2009 11:58 AM
joeford150
New Hampshire Chapter
Sep 2, 2003 11:09 AM
