Payload Capacity?
Old Aug 28, 2012 | 06:21 PM
geoffunkel's Avatar
geoffunkel
Payload Capacity?
I have a 1989 F-250 Heavy Duty Super Cab Long Bed. I have to transport 2.5 cubic yards of 3/4" aggregate rocks for a job I am doing next week. I'm estimating 2,800 lbs per cubic yard. I'd like to know how much I can transport legally and safely in my truck bed. It's only about a mile from the rock place to the job site so I won't even be on the freeway. The truck has a rear GVWR of 6,084 lbs and a total GVWR of 8,800 lbs. My rear tires are stock-size, good condition and pumped up to 80 PSI. They have a load range "E" and have a listed 3,042 lbs. capacity per tire.
So, I'm estimating the truck weighs about 5,800 lbs unloaded??? So I can have about 3,000 lbs in the bed. Does that seem about right? I would assume the truck could actually handle WAY more than that, but don't want to get hit with a ticket for exceeding my GVWR.
Old Aug 28, 2012 | 06:34 PM
geoffunkel's Avatar
geoffunkel
I guess the real question here is what is the curb weight of my truck unloaded. It is a super cab 2wd and has the 460 with ZF-5 Speed. I'm guessing 5,800-6,000 lbs???
Old Aug 28, 2012 | 07:02 PM
geoffunkel's Avatar
geoffunkel
Perhaps I'll just go to the dump and ask them to weigh my truck...
Old Aug 28, 2012 | 07:21 PM
norfolknova's Avatar
norfolknova
That would be the best way, weigh it at a scale. Make sure you and any regular cargo are in the truck, and if you really want to be safe make sure it is full of fuel. Remember gas weighs almost 8 lbs pr gallon.
Also the gravel yard may have a scale. i know the local gravel yard here in Norfolk has scales.
Matt
Old Aug 28, 2012 | 07:43 PM
ewalt98's Avatar
ewalt98
As norfolknova mentions, the yard may have a scale. You can do a weigh in, and weigh out to see the diff.
I frequently get a yard or so of gravel, which is often wet, in my one ton, and it is usually around the 3000# mark. Even with air bags and the tires at 80psi, I can feel the weight. I've had more weight in it, and I could fit more gravel than I usually do, I don't bother.
I would guess that you will need to make at least two trips at the minimum.
Old Aug 28, 2012 | 08:01 PM
geoffunkel's Avatar
geoffunkel
Thanks for the info. I was planning on two or three trips. I was thinking the yard probably would have a scale as well, but I wanted to know before I got there for my own reference. I will take the truck to the scale tomorrow.
Old Aug 28, 2012 | 08:03 PM
Diesel_Brad's Avatar
Diesel_Brad
Your truck weighs about 6500
Old Aug 28, 2012 | 10:33 PM
burnout400m's Avatar
burnout400m
That's about right. I had my '90 SCLB 4x4 weighed with my fat butt in it is was around there, I don't recall the exact number, also my tanks were kinda low.
Anyway I'd say 2,800lbs is just a little over capacity plus whatever you, the fuel in the truck, and any other gear in the truck weigh. Rough guestimate you'd be close to 1k over GVWR. Sounds to me like two trips would be a good way to go or possibly put some in a trailer.
Old Aug 29, 2012 | 05:38 AM
jroehl's Avatar
jroehl
Originally Posted by norfolknova
That would be the best way, weigh it at a scale. Make sure you and any regular cargo are in the truck, and if you really want to be safe make sure it is full of fuel. Remember gas weighs almost 8 lbs <acronym title="Page Ranking">pr</acronym> gallon.
Matt
Gasoline weighs around 6 lbs per US gallon (different formulations can bump it up to around 6.25 lbs/gallon). Water weighs about 8.34 lbs per gallon. Google is your friend!
The only truck I ever had weighed was my '90 F150 (Reg cab, longbed, 302/AOD/2wd), and at a gravel pit, it weighed around 4400 with me and about 15-20 gallons of fuel in it.
Jason
Old Sep 5, 2012 | 05:14 PM
geoffunkel's Avatar
geoffunkel
For the record, I had my truck weighed today at a certified scale. It weighed in at 5,900 pounds with my camper shell on. This is totally unloaded with no driver, passengers, cargo, etc and about 10 gallons (60 lbs.) of gas in the tanks.
I'm estimating the camper shell is about 200 pounds so the unladen weight of the truck with a normal amount of gas is 5,700 pounds. So with a GVWR of 8,800 pounds, and camper shell off, I can legally have an extra 3,100 pounds of passengers and cargo in the truck. So, it's safe to say my actual bed payload capacity is about 2,800.
Again this is a 1989 F-250 Heavy Duty XLT Lariat Super Cab 2wd with 460, stock wheels and tires, and ZF 5-Speed. Confirmed to be 5,700 pounds by a certified scale.
Old Sep 5, 2012 | 06:46 PM
Opossum's Avatar
Opossum
The only numbers that really matter is that 2.5 yards at 2,800 a yard is 7000, so 2333 per trip if ya take 3 even trips, or 3500 per trip for 2 trips. So can you handle 3500, sounds like a no, so your taking 3 trips.
The rear tires are usually the limiting factor, you said 3,042 per tire and 6,084 rear GVWR, anyone else find it odd that these numbers exactly match, that 2 tires at 3,042 is exaclty 6,084? You may want to double check that. That said you missed a chance to get an important number at the scale, the weight on the rear axle is what ya really need to know. Being an older F250 your springs might be a little soft but my 87 F-350 also shows a rear GVWR 6,084 so maybe there the same springs and I wouldn't sweat a 3500 bed payload but I got 3970 ratings on my tires.
Old Sep 5, 2012 | 09:04 PM
Lead Head's Avatar
Lead Head
GAWR is set by the weakest link in the chain. The 10.25" axle isn't the weak link in this case, it's the specific rating tires that came out of the truck from the factory.
Old Sep 5, 2012 | 09:17 PM
Opossum's Avatar
Opossum
Right, and it occurs to me that maybe the 3042 in the OP is off the door sticker not the actual tires. And of course I assumed an 89 doesn't have the factory tires, the factory tires certainly didn't take 80psi. Time to take a look at the tires themselves.
Old Sep 5, 2012 | 09:30 PM
jroehl's Avatar
jroehl
That's a load range E tire. My '93 has the exact same ratings (super cab, long bed F250HD). The door sticker says 80 PSI for the rear tires and 51 PSI for the front, and a GAWR for the rear axle of 6084 lbs. But, if you take the axle code (mine is 35) and look it up in the nifty FTE list (at the top of the screen under Articles/Specs > Decoders/Charts ), you'll see that the axle is actually rated for 6250 lbs.
All the E-range tires I've seen at that size (235/85R16, IIRC) have had a weight rating of 3042 lbs @ 80 PSI molded on the side--I've had to shop for the tires a couple of times.
Jason
Old Sep 5, 2012 | 09:56 PM
Opossum's Avatar
Opossum
Jason
OK nevermind then, frankly I don't think I have ever shopped for factory size tires. Currently I run a 37x12.5R16.5 that are "load range E" and 3970lbs at 65psi. I wonder why so consistant at 3042, assuming it's true anyway.
Hmm gunna have to go see if I can read that part of the door sticker, it's not all that readable anymore.
Edit, well shoot that's what mine says, good info on there when you can read it, lol
