1978 - 1996 Big Bronco
Turn Signal
Old May 14, 2003 | 11:45 AM
Zukster's Avatar
Zukster
Question Turn Signal
Here's a new wrinkle...I noticed coming home from work yesterday that the turn signal light (the left one) on my instrument panel (little arrow) was not blinking off and on, but both the front and rear turn signals were working. Now this morning, the light on the instrument panel was blinking. Any ideas?
Old May 14, 2003 | 05:40 PM
greystreak92's Avatar
greystreak92
Turn Signal
Loose lamp in the instrument cluster. OR a partially broken filament in the lamp that when bounced around occasionally touches the post inside the lamp and incandesces (sorry - lights up). Either way, its a trip inside the dashboard to find the problem. I would personally recommend that since you have problems with one of the lamps in there and you are going to have to pull the dashboard apart to fix it, you might as well, replace them all. Then you KNOW they are all new and you shouldn't have to worry about the same thing happening again in a couple of days, weeks, or months with one of the other lamps in there. Those lamps are usually rated at a 3500-4000 hour life but thats in a controlled laboratory environment, not bouncing around in the truck.
Old May 15, 2003 | 06:13 PM
DRK's Avatar
DRK
Turn Signal
I had the same problem. My bulb was loose.
Dk
