emissions equipment
Member of this forum has a 1976 F350 390 4V Super Camper Special (10,000 lbs. GVW), bragged in his sig pic that it didn't come with any emissions equipment, including a smog valve (PCV mandatory in all sold new in CA vehicles since 1961, other states have required PCV since the mid 1960's). I told him a PO had removed all the jazz and I could prove it.
I drove out to San Berdoo where the truck is located, looked on the Warranty Plate for the DSO code: 72, truck was sold new in NorCal. Raised the hood, looked on the right (passenger) side frame rail below the alternator. There it was, the Evaporative Emission's charcoal cannister, without anything attached to it. Hoses that routed from fuel vapor valves in fuel tanks along frame rail to cannister missing, but the retaining clips were there.
Restrictors knocked out of fuel filler tubes, 2 pronged vented fuel caps replaced 4 pronged non vented caps. EGR valve removed, holes where it mounted to the EGR/Carb spacer plate blocked off. All the T/E parts were gone, threaded holes in cylinder heads where T/E manifolds attached, plugged off. (460's have a T/E Y pipe at the back of the block that connects to both heads, check valve threads to 3rd leg of Y).
Grommet in right (passenger) side valve cover with smog valve in place, but no hose from valve to carb nipple, as it was capped off. / Left valve cover: Original oil cap has a hole in it, rubber grommet fits into hole, plastic elbow fits into grommet, hose routes from elbow to nipple on air cleaner...except: Original air cleaner replaced by a gypo, so nothing could be attached to it.
Oil cap also replaced by a gypo chromo, had no hole in it. So, not only was the original air cleaner MIA, but...so was the preheat tube, snorkle with flapper valve/vacuum motor, crankcase ventilation filter and everything else.
CA smog tests all 1976 and newer vehicles, all the emission related parts have to present and in good working order. If it cannot pass smog, it cannot be registered, it's a simple as that. There is no waiver if the parts are obsolete.
It's fix it...or park it...and this truck has been parked since 2008! And the braggadocio has been removed from the members sig pic.
If AZ has exempted certain year vehicles, then that's what I recommend pursuing.
Some states,, depending on GVWR, had different emission requirements,,,
You should be able to go to a smog station,, with the VIN and they should be able to tell you what it came with,, check on the Driver side valve cover,, my 351Measly has a sticker that states NON-Catalyst,,, good luck!
Everyone knows emissions laws are
Fritz
If this was the 1961/66 forum, truck was an F100 I-6/352, then it could have T/E, depending on state emissions laws. CA fer sure.
C6AZ-6052-A .. Threaded Plug (1/2" -20 x 1 11/32"), used to plug T/E holes in cylinder heads: 1966/68 240/300 & 289, 1968 302, 1966/76 FE engines.
Hell, if this was the case, CA residents could buy any 1976 and later collector vehicles and then tell the CA Air Resources Board & DMV to shove it!
But it isn't possible in CA and I doubt in any other state, it could be possible either. It's a FELONY in some states to remove emissions related equipment.
PVC valve & fuel vapor canisters. That is it! No EGR, no cats, no smog pumps NADA!
California trucks do get the EGR. I can deal with adding the vapor canister(s) Open air filters are OK too as long as it has the PVC vent hose attatched.
Love it when a plan comes together!!PVC valve & fuel vapor canisters. That is it! No EGR, no cats, no smog pumps NADA!
PVC valve & fuel vapor canisters (Evaporative Emission System) That is it! No EGR, no cats, no smog pumps NADA!
All the parts (there are dozens!) are obsolete except the fuel vapor valve. Kinda hot in Arid-Zon-A this time a the year to be searching one junkyard after another trying to find the missing parts.
And, since this is monsoon season, where rain pours down from the heavens, don't forget to take your bumbershoot along.
And btw: EGR valves were installed in every automakers vehicle beginning in 1973, mandated by the US Gov't. Better call nice lady back and verify, because when you go to smog it, nice lady won't be there.
From this, it appears Michigan is pretty lame:
Michigan Budget and Economic Facts [Mackinac Center]
Yea I'm OT but WTF inspires people to come to these threads with their simple solutions like "move to Michigan/BFE/SomeotherShole where we have no laws...."
