Rare problem
Old Aug 27, 2012 | 08:15 PM
JT250's Avatar
JT250
Originally Posted by thomabb
Ah, you are on to something here. If your rears are in the air you should be able to spin them. Was this before or after the oil change?
When was the last time you checked your parking brake? The lining can delaminate from the shoe and cause what you are describing.
Is this all the time or only when it is in neutral?
Old Aug 27, 2012 | 08:22 PM
dothedew192's Avatar
dothedew192
I followed guzzles maintenance website (http://www.guzzle7pt3.com/rdiff.php) when i changed my fluid and his instructions said it took 3 1/2 quarts of synthetic 75w 140 and if its limited slip add 4 oz of ford xl friction modifier. Both of those were exact measurements for my truck. How much fluid and modifier do you think you added?
Old Aug 27, 2012 | 08:33 PM
Sirpecka's Avatar
Sirpecka
Originally Posted by dothedew192
I followed guzzles maintenance website (Welcome to guzzle's Rear Differential Maintenance Web Page) when i changed my fluid and his instructions said it took 3 1/2 quarts of synthetic 75w 140 and if its limited slip add 4 oz of ford xl friction modifier. Both of those were exact measurements for my truck. How much fluid and modifier do you think you added?
I took the4 oz friction mod and poured it into my first quart of oil then it took 2 more quartz and then started to overflow it was like 3 quarts and a little bit out f the 4th then it was full
Old Aug 27, 2012 | 11:17 PM
szotty's Avatar
szotty
i would double check the e brake cus both of mine were hanging up not returning all the way so i had to tear alll apart and clean and grease little bit for them to release all the way
Old Aug 28, 2012 | 12:54 AM
4inchlovin's Avatar
4inchlovin
TOTTAL SHOT IN THE DARK...
I have had a similar issue along with a similar issue in my boss's excursion. Peter (Duck Fan) suggested the we pull apart the TPS (Throttle Posistioning Sensor) and clean the contacts with spray. We did this in both vehicles and have not had any issues yet. Just my .02c
Old Aug 28, 2012 | 02:23 PM
F250_'s Avatar
F250_
Originally Posted by Sirpecka
Well my rear diff cover is stock cover from AutoZone so it shouldn't be any higher capacity. I filled it until it started dumping out the overflow and then sealed it. I was told to fill it till it spilled out the overflow andcap it off. Is that to much?
Not too much.
Old Aug 28, 2012 | 02:50 PM
Sirpecka's Avatar
Sirpecka
Well heres whats happening now. It has just randomly stopped doing it hahaha. So im not going to worry about it. Im selling the truck now anyway. Im leaving PSD and going back to the old 7.3 IDI. Found a wicked nice 1994 F350 Super Cab Dulley im probably gonna get. I need to get a heavier truck for things im going to be doing in the near future. Im not one for heavily modding engines or anything like that. Ill probablly put a different turbo on it but im tired of working on my PSD all the time. With the IDI parts are cheep and in the end its only like 10 horsepower less then the stock PSD. I love the old style too.
Old Aug 28, 2012 | 03:21 PM
JT250's Avatar
JT250
Same topic, kinda, but I jacked up my rear end and spun, spinned? ...whatever....and they turned, freely, not easily. Question is does the limited slip cause them to spin together in the same direction? I guess I am just used to an open diff that spins opposite.
Old Aug 28, 2012 | 11:37 PM
Bonanza35's Avatar
Bonanza35
Yes they do.
Mary Smith Harner
1997 - 2003 F150
22
Sep 10, 2014 03:45 PM
rtazz17
41
Jul 1, 2011 04:20 AM
iam me
Aug 19, 2009 05:59 AM
cjcocn
May 31, 2009 08:40 AM
mongo75
May 6, 2008 08:26 PM
