Sponsored by: Real Truck
tuning question
Old Aug 26, 2012 | 04:28 PM
es1982's Avatar
es1982
tuning question
Ok so I finished the rebuild for my F250 heres the stats
1999 F-250
V-10
Auto
bored 30 over
Ported PI heads
Ported PI intake
Comp Cams
Diablosport tuner
The truck starts and idles fine but when I floor it it revs up to about 1000rpms then sputters and breaks up like its not getting fuel then at about 2000rpms it comes to life and screams. When I put the motor together I used the 24# injectors from the PI motor instead of the 19# injectors from the non PI motor. The MAF is from the non PI motor. Could the heads be flowing so much air that the MAF isn't telling the injectors to work more and the o2 sensors are reading lean then telling the pcm to give it more fuel? If this is the case is there a PID i can change with the Diablosport to cure this. Right now the tune is stock I haven't tried changing it and seeing if that fixes it. Could I just get a MAF from a PI truck engine? How do I know what to change with the Diablosport to give it more fuel? Does anybody know a place in North Eastern PA that can Dyno Tune it for me? Thanks
Old Aug 27, 2012 | 06:49 PM
es1982's Avatar
es1982
nothing? can sombody move this to the V-10 section i didn't realize it was there when i first posted it
Tbug05LTD
Apr 8, 2020 07:15 AM
iridiumred
Oct 28, 2009 03:17 PM
ReAX
Modular V8 (4.6L, 5.4L)
May 19, 2006 09:20 PM
wdb1971
Aug 8, 2005 08:17 PM
Bigmark'sblownv10
Modular V10 (6.8l)
Mar 27, 2005 04:16 PM
