gastank problem
Old May 14, 2003 | 06:25 AM
sandmanf250's Avatar
sandmanf250
gastank problem
I have a 1954 pickup with a 6 volt system but converted to 12 volts.The gas tank sending unit seems to be reading double the gas thats in it.Do ineed to add a resistor or something to reduce the voltage?
Old May 14, 2003 | 08:42 AM
William's Avatar
William
gastank problem
Do you have a resistor on the gage? Ford calls this a "constant voltage regulator". It is a small silver box, (on 60's vintage stuff not sure about yours), and is usually located on the cluster. Since your truck was 6v it may not have had one and you should try reducing the voltage to the gage first. How about the temp gage and oil pressure? After that I'd try some resistance in the sending unit wire.
