A/C problem
Old Aug 25, 2012 | 08:41 AM
corwin132's Avatar
corwin132
A/C problem
my A/C clutch pulley is not engaging. if i jump the coil to the batt. it engages. im getting 10.20 volts at the plug while it is disconnected from the coil with the A/C on. did the air gap fix. anything else i should check. thanks for any info
Old Aug 25, 2012 | 10:55 AM
bcaughhorn's Avatar
bcaughhorn
have you checked the psi with gauges? maybe you could try to bypass the low pressure switch. it may be bad
Old Aug 25, 2012 | 11:26 AM
SARDiverDan's Avatar
SARDiverDan
I was going to ask the same question, what psi values are you reading?
Old Aug 25, 2012 | 03:57 PM
corwin132's Avatar
corwin132
it was low pressure switch. thanks for the help
LCA078
17
Mar 13, 2025 02:36 PM
Skydivelout
Sep 17, 2015 07:33 AM
PowerstrokeDude
Apr 8, 2007 02:10 AM
bryan1
1978 - 1996 Big Bronco
Jul 28, 2005 08:02 AM
yezek6
Aerostar
Jul 24, 2002 11:00 AM
