1978 - 1996 Big Bronco
What did you do to the Bronco Today?
Old 08-26-2012, 06:23 PM
1_ton_bronco's Avatar
1_ton_bronco
1_ton_bronco is offline
HD BUMPER
old warn enforcer bumper i made some sides and put some tubing on it
still not done..
Old 08-26-2012, 06:39 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
Finished up rebuilding my hubs. It was a pain but i got it done. I also drove down to AutoZone to buy my neighbor a new Spindle Nut Socket. I kinda jacked his up...
Old 08-26-2012, 07:02 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
Put a new copper exhaust gasket on one side today.
Old 08-27-2012, 09:58 AM
Boss351Bronco88's Avatar
Boss351Bronco88
Boss351Bronco88 is offline
Bought Timing Tape, and a MSD Digital 6AL box (one with the Rev Limiter) for the Bronco. Going to Order a 3in Electric Dump later on this week. And prepping tools and the garage for the motor install this upcoming weekend.
Old 08-27-2012, 04:23 PM
GruesomeJeans
I tried and failed at replacing some fuses. I have the glass ones and the PO decided he was too cheap to buy some so he used tin foil. Of course this doesn't jive with me too well so i figured i would take a look and fix it. Turns out i don't have the correct fuse either... I did however pull the tin foil out for safety sake. once i get some more fuses that will work i can fix it. One was for the instrument cluster and the other i am not sure about. All it said was coast Lbs and it was i think 15 amp.
Old 08-27-2012, 09:19 PM
bigzirb's Avatar
bigzirb
bigzirb is offline
I finished welding the firewall and painted it. I went back to working on my front hub rebuild. TGM is inspiring me. I dug out the bumper I am going to be using on the rear of my Bronco and started figuring out how to modify it to work.
Old 08-28-2012, 02:11 AM
GruesomeJeans
Glad to hear that something positive is happening from TGM
Old 08-28-2012, 02:36 AM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
Thought about starting it, but was too lazy to
Get the keys. Maybe tomorrow.
Maybe not, two other trucks need oil changes.
Old 08-28-2012, 03:03 PM
bigzirb's Avatar
bigzirb
bigzirb is offline
Ordered all of the wheel bearings and seals to rebuild 1 side of the front axle. Since I am converting it to 8 on 6 1/2 outers from a Dana 44 HD to make the front match the Dana 60 rear. I figured this would be a great time to rebuild everything. I only got 1 side cause it will probably be another few months before I got to the other side...
Old 08-28-2012, 04:11 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
Hope to finish installing teh new gaskets today. The Wife wants to learn how to work on cars so its going slow.
Old 08-28-2012, 04:40 PM
GruesomeJeans
Yeah learning how to work on cars. Putting headers/gaskets on is the best place to start! I haven't done it yet, but i plan to use TGM today to help a friend and co-worker of mine move out of her apartment. Now that i can safely drive it, it is the only truck she knows up that can haul her bed and chair.
Old 08-28-2012, 05:16 PM
Captbs32's Avatar
Captbs32
Captbs32 is offline
Figured out it needs u-joint(s) really bad. SWEEEEEEk
  #28
Old 08-28-2012, 09:07 PM
GruesomeJeans
Aw man, u joints are never fun... Especially that double cardon joint.. What a pain.
  #29
Old 08-28-2012, 11:00 PM
bigzirb's Avatar
bigzirb
bigzirb is offline
I picked up my wheel bearings from Auto Zone then got in trouble when I got home for spending too much time in the garage. I agreed to spend time with my wife and son in the house tonight. I made dinner, gave him a bath, and put him to bed. Then I sat on the couch with my wife while she watched her TV shows and I started typing up my build thread (finally) on the laptop while sitting next to her.
Here it is.
https://www.ford-trucks.com/forums/1...big-truck.html
At least that is the start, I'll keep updating it as I have time until I get it to where I am now.
Stay safe and keep working on those Bronco's!
  #30
Old 08-28-2012, 11:37 PM
pintoches's Avatar
pintoches
pintoches is offline
Bigzirb, Already following your build,looks Good! Mine started out the color too.
Playing with the bronco today, Switched the vacuum advance from a ported vacuum on the carb to full time manifold vacuum. Found out the advance in the dizzy is bad. So that could be why it pops so much When I get on it?
Hope to find the other dizzy this weekend!
Quick Reply: What did you do to the Bronco Today?
