1978 - 1996 Big Bronco
What did you do to the Bronco Today?
  #2296
Old 08-09-2014, 12:33 AM
blackjack33's Avatar
blackjack33
blackjack33 is offline
Originally Posted by GruesomeJeans
I wish, they are based out of New York. They make a tonneau cover type thing. I'll have to find the site but I can link to you. I wish they were here they need a 78 bronco to use as a "model" to make the tops for 78-9.
EDIT: here is the link bronco tonneau
Its a "Fastback" style top. I kind of like the way it looks.
Thanks man!
  #2297
Old 08-09-2014, 01:50 AM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
Originally Posted by Fordman96
I know what place you are talking about, but I'm drawing a blank on the name. I know for my 96' it's like $1,200 without the rollbar that holds the top.
I thought JBG sold them for the 78/9?
The place I posted about was cheaper. It was around 800 ish.
As for JBG, they dont have any as far ad I know. I believe theirs stop at 81 or something. Not even this place has one for 78-9, they need a truck to use for a "model".
  #2298
Old 08-09-2014, 10:57 PM
FourXFord2's Avatar
FourXFord2
FourXFord2 is offline
Installed new brake and clutch pedal covers. Bought new brake drums, pads for the 10.25 rear.
  #2299
Old 08-10-2014, 12:10 AM
blackjack33
I skipped the interior detail today...painted the topper instead.
  #2300
Old 08-10-2014, 10:16 AM
wolfie1961's Avatar
wolfie1961
wolfie1961 is offline
Replacing the radius arm bushings and brackets.
  #2301
Old 08-12-2014, 11:41 PM
FourXFord2's Avatar
FourXFord2
Went back through all the wires and triple checked everything I have shoved into a connector so far. Still have a couple strays still looking for the correct home and might have to splice one wire into vehical harness.
  #2302
Old 08-13-2014, 10:58 PM
FourXFord2's Avatar
FourXFord2
Installed new chrome door handle on drivers side. Spent 4 hours poking at wires and connectors. Bumped interior hood latch and it now needs replaced,need to shop for that tommorow.
  #2303
Old 08-19-2014, 04:21 PM
FourXFord2's Avatar
FourXFord2
Buttoned up the engine and dumped 6 qts of 10w40 into crankcase, spun on a new filter and filled radiator. Went to start it and feels like the ignition actuator is broke, again. Made sure trans was in neutral and connected the remote start button under the hood, tried to turn it over and got nothing, starter must be stuck? Tapped switch a couple more times and smelled soething electrical warming up. Then fuel pump kicks on again, panic, pulled the negative cable and started looking. Battery is fully charged 13.5vdc, reconnect the battery and nothing, no dash lights, no interior lights, nothing!!!
This '91 is trying to give me a stroke! Going back out to start the troubleshoot, wish me some luck guys!
  #2304
Old 08-19-2014, 07:51 PM
FourXFord2's Avatar
FourXFord2
That was easy
It helps if the negative terminal is tight. Since that only took about 10 seconds I fixed the broken ignition actuator. Yes, I do carry spares limited lifetime warranty or not, Iv'e had too many break to not. I did take a bunch of pics, step by step, how-to thread in the works
  #2305
Old 08-19-2014, 09:52 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Shame on you! blaming that poor Bronco for your mistake...
  #2306
Old 08-19-2014, 10:56 PM
FourXFord2's Avatar
FourXFord2
Well, it cranks over, has fuel pressure, spark, won't start. It has me a bit puzzled, even checked if there were any KOEO codes, 11, 11.
  #2307
Old 08-22-2014, 10:20 PM
FourXFord2's Avatar
FourXFord2
I got it to fire, with some ether. Put a light bulb in injector connector and nothing, tester shows 12v, so trouble with a ground or EEC. Ready to start rear axle swap this wekend.
  #2308
Old 08-25-2014, 03:50 PM
MadMatt65's Avatar
MadMatt65
MadMatt65 is offline
Well....after a "Bronco Hiatus".......I've started putting the Ole Bronco back together. Found a wrecked Bronco with a very recent rebuilt E4OD. Got it pretty cheap...hope it's OK. Hopefully....the trans is OK and that will give me time to save and get my E4OD rebuilt with all the good stuff by a buddy down here. (That's the plan anyway!!) Waiting for the Derale pan and aux. cooler to get here. That's when I noticed my NEW JBA headers weren't in the back of the Bronco. Pretty sure they were with some of my stuff at my friends shop. Anyway, they're gone.
That starts me on a small rabbit trail. Does anyone have "Full length" headers on their 92-96 Bronco???? I'd like to see pics. Trying to decide full length or shorties. Thanks!!
  #2309
Old 08-30-2014, 07:08 AM
justforkicks's Avatar
justforkicks
justforkicks is offline
I looked at mine last weekend. Both my 96 351 and my 84 302. Made me sad. Poor old 84 has no rust but doesnt have a straight body panel on the drivers side and needs a trans. 96 needs all new panels, tailgate, rear window, windshield, grill, header panel, headlights, bumper, and the engine has a rod knock.
Also been tossing around the idea of selling the 84.
  #2310
Old 08-30-2014, 08:35 AM
GruesomeJeans
I haven't done much, I bought a battery for mine so I can start trouble shooting. There was an interesting noise last time I ran the motor.
Quick Reply: What did you do to the Bronco Today?
