hey AXracer . . .
Old Jan 9, 2013 | 05:46 PM
Jasonnoel's Avatar
Jasonnoel
Originally Posted by teardropty
Oops, yes, PUMP not box. I will edit that out. LOL Wouldn't that be a nightmare trying to modify the box. Here are a few pics.
FYI - There is also a mounting point tucked between the GM alternator and pump. You can't see it in the photos. There are a total of 3 bolts/mounting points holding the pump on. The key is finding the right tension between the alternator belt and the pump belt. They adjust in opposite directions, hence the reason I used the Acculink adjustable V-belt so I could finetune. Trust me, once the belt breaks in one link has to be removed. I still like this setup over trying to use a double pulley on the fan side of things.
Did the Alternator wear out or cause any issues with the power steering pump?
Bercier Brian
Jul 19, 2018 05:26 PM
Martin Torres
Mar 2, 2018 07:45 PM
brenjimin
Mar 28, 2016 03:29 PM
RedZombie
Sep 17, 2008 11:56 AM
Goobzilla
Aug 9, 2002 06:18 AM
