Both of the dust seals on the front drive axel have popped out and I am considering having Ford replace them under warranty. I see that the new Ford seals are metal instead of rubber that came from the factory.
Has anyone had the new metal seals installed and have they had any problems with them?
Should the other internal seals be replaced at this same time or will Ford just reinstall the factory ones?
My truck is a 2009 F-250 XL 4x4 AT 6.8L with 46,250 miles on it.
Thanks to all replys.
