Looking at an '05 F-150 XL this afternoon with a 5.4 and factory tow package. Is there a way to ascertain the gear ratio and the presence of a T-Lok diff without crawling under the truck?
Vehicle has 100,000 miles. Anything I should check out in particular?
You can determine the rear gear ratio from the sticker on the drivers door jamb under Axle Code I believe. H9 which is a 3.55 and B6 which is a 3.73 are fairly common ones. Check out the ones below if it is not one of those.
