VIBRATION!!!!!
Old Aug 19, 2012 | 07:27 AM
wsdkmd5568's Avatar
wsdkmd5568
Unhappy VIBRATION!!!!!
I HAVE A 97 7.3 POWER STROKE DIESEL TRUCK. THE LAST DAY OR 2 WHEN I HAVE BEEN DRIVING IT I NOTICED IT HAD A VIBRATION WHEN DRIVING, SEEMS TO BE COMING FROM MOTOR OR TRANSMISSION, THE DASH STERRING WHEEL EVERYTHING WOULD VIBRATE, THE OTHER DAY I WAS DRIVING IT I HEARD LIKE A GRINDING NOISE AND THEN THE TRUCK CAME TO A STOP, THE MOTOR WAS STILL RUNNING BUT WHEN PUT INTO GEAR IT WOULD JUST GRIND SO I SHUT THE TRUCK OFF TO GET UNDER IT I CAN TURN THE "FLY WHEEL" BY HAND FREELY. AND WHEN I TRY TO START IT ALL IT DOES IS SPIN AND THE MOTOR DOES NOT ROATATE. ANY HELP, I WAS TOLD THAT THE CRANK SHAFT BROKE, COULD THAT BE THE ANSWER?
Old Aug 19, 2012 | 07:31 AM
Mdt1992's Avatar
Mdt1992
dual mass fly wheel came apart?
Old Aug 19, 2012 | 07:41 AM
wsdkmd5568's Avatar
wsdkmd5568
the fly wheel is connected to the torque converter, is it possible that the fly wheel came apart from the shaft? not really auto techinical
Old Aug 19, 2012 | 07:44 AM
Chris56ford's Avatar
Chris56ford
lost
Based off your other thread, I assume you have an auto. Sounds like your flexplate broke in the center around the bolt circumference.
Old Aug 19, 2012 | 07:50 AM
Chris56ford
lost
The flexplate is that big gear looking thing that the starter uses to start the truck. It attaches to the crank and the torque converter. A flywheel goes with a manual tranny, a flexplate goes with an auto.
Old Aug 19, 2012 | 07:52 AM
wsdkmd5568's Avatar
wsdkmd5568
yes its an automatic, when im under the truck and turn the fly wheel it turns the tourge converter as well if it is broke around the bolt pattern should the tourqe be moving?
Old Aug 19, 2012 | 07:58 AM
Chris56ford
lost
Yes it will still spin, the torque converter is unlocked from the trans. The torque converter also keeps the flexplate in its original position as if it wasn't broke, it will not come out without taking the trans out.
Old Aug 19, 2012 | 08:05 AM
wsdkmd5568's Avatar
wsdkmd5568
got it!!!! so its more likely to be the flexplate than the crankshaft correct
Old Aug 19, 2012 | 08:14 AM
Chris56ford
lost
Correct, here is a picture for reference to what I'm talking about, notice the center of the flexplate is broken out.
Old Aug 19, 2012 | 08:21 AM
wsdkmd5568's Avatar
wsdkmd5568
cool, i had an half *** mechanic tell me it was the crank shaft that broke and the motor had to be rebuilt or a new one put in, i thought it was kind of fishy because i would of thought if the crankshaft was bent or it even broke while driving it would of caused some kind of damage to motor and made more noise than a little grinding like someone couldnt shift gears.
Old Aug 19, 2012 | 08:29 AM
Chris56ford
lost
Ya I would stay far away from that "mechanic". I have never heard of a 7.3 crank breaking and it still run. Plus, to break a crank it would take $$$$$ in mods and a huge amount of power coming out of that motor. Pull your trans and I'm sure you will have a broken flexplate, pretty common problem.
Old Aug 20, 2012 | 01:41 AM
95_Dually's Avatar
95_Dually
Like Chris said, the flex plate is pretty common. On a side note, broken crank while driving will most likely result in....internal parts exiting the block and creating a massive oil leak. Don't ask how i know.
Old Aug 20, 2012 | 06:20 AM
wsdkmd5568's Avatar
wsdkmd5568
THANKS FOR THE HELP GUYS. DO ANY OF YOU A GOOD PLACE TO ORDER A FLEXPLATE FROM?
Old Aug 20, 2012 | 08:49 AM
DIYMechanic's Avatar
DIYMechanic
I don't know anything about the quality of the ATP parts line, but Rock Auto has an ATP flexplate for your truck for $52.99.
Old Aug 20, 2012 | 07:45 PM
BuckHammer's Avatar
BuckHammer
I'VE GOT MY OLD FLEXPLATE SITTING AROUND SOMEWHERE. YOU CAN HAVE IT IF YOU SPRING FOR SHIPPING. SEND ME A PM IF YOU'RE INTERESTED.
