brake light switches
Old May 13, 2003 | 01:36 PM
shoman4000's Avatar
shoman4000
i have a 1963 and a 1964 and on one of them i cannot get the brake lights to work. ever since i have had this truck i have had this prblem on and off. i have put a new brake light switch on it a couple of years ago (doesn't mean anything, it could be bad) and i have also replaced the wire connectors that plug on the brake light switch on the master cylinder. for a while after i did all this, i had no problems out of them. then, when i got it back out to drive it, they quit working again and i have no idea what the problem is. i cannot even find where the lights are grounded at to check that. If anyone can help me, please please let me know. thank you
Old May 13, 2003 | 02:52 PM
44dwarf's Avatar
44dwarf
I think the lights get grounded through the light housing with the two philips screws that hold it in to the bed.
44Dwarf
Old May 15, 2003 | 08:37 PM
66Ford my baby's Avatar
66Ford my baby
First thing. Check to see if you have voltage at the switch.
If no voltage check fuse at the fuse box.
Do your turn signals work?
Post back and I can tell you more.
Old May 16, 2003 | 08:28 AM
Bigiron427's Avatar
Bigiron427
I had the same problem with my '65 F-100, I ran a hot wire from the fuse box to the switch, no more problem. Small guage wire so it wouldn't look too bad.
Old May 18, 2003 | 08:40 PM
d1a2n3e's Avatar
d1a2n3e
My turn signals or brake lights wouldnt work when the turn signal cam under the steering wheel was loose so I pushed it down tight and it works,every once and a while it gets loose and they go out.
Old May 23, 2003 | 07:45 AM
leonharu's Avatar
leonharu
Are you by any chance using silicone brake fluid?
Russell
