This is prolly a 1 page thread at most
So we mounted it directly in front of that cross member that forms the shelf above the spare. I suspect the outer ring of the tire will be right under the unit. I'll get a photo today. It's still up on the lift with the tires off, So it's easy to get a photo of, even for guy with trying to recovery from knee replacement. that is the reason I let the diesel brothers do this. There was no way I getting on my hands and knees and crawling under this truck to work on it. My knees are getting better, but I'm NOT CRAWLING on them yet.
Received 5,381 Likes
on
Don, what kind of furnace do you have there, electric or wood or natural gas or propane ????/
Eric, I hope that all melts by the time you're ready to go outside, good luck.
Jon, I agree, that's a job for the diesel brothers ..........
welcome to December boys, I'll be glad when the year and winter is over
where's Roy
Andre, those deicing chemicals are worse than salt I think ....... yuck
where's Roy
Received 3,952 Likes
on
where's Roy
where's Roy
I got off the hook, no snow blower operation today. It quit snowing since the pics. When I was 12, would have spent all day rolling around in this. It is perfect snowball snow. Also perfect for snow forts and snowmen. Alas, I don't have the same desire to do those things anymore. Shoveled the deck and a little in front of the garage and called it good enough.
It does snow here off and on between now and late April. Not a lot the last few years, but you never know. 50 miles east of here they get persistent lake effect snow off of Lake Erie, 2-3 times as much as we get.
Compressor above spare tire
I put the intake filter behind the back seat so it’s sucking in cabin air
Here is the airbag on driver side the boys did a really clean install
the leveling kit raised the front 2.5” so I’m sitting almost perfectly level with 10 psi of air in bags
steering wheel is slightly off. So I’m at Les Schwab now to get alignment snd recenter steering wheel
that may be the extent of my modifications until find some work can’t spend like a drunken sailor if it’s all coming out of savings.
