Sponsored by: Real Truck
Better shift points
Old May 13, 2003 | 12:19 PM
FredMez's Avatar
FredMez
Better shift points
After reading the FAQ, I understand that all of the performace chips offer more horsepower and more torque. They also offer better and firmer shift points.
My question, is there a way to get the improvements of the shifting with the changes to the engine programming? My main reason for asking is that I feel I have plenty of power in the engine and do not want to pay more for higher octane gasoline (because most chips require higher octane gas), but the shifting of the transmission has much to be desired.
Thank you, sorry if this is addressed in the FAQ, but I did not see it.
Old May 13, 2003 | 01:38 PM
ArkansasFordMan's Avatar
ArkansasFordMan
Better shift points
I believe that you can get just a shift improver kit from a tranny company like B&M or any other reputable tranny shop. B&M is very well known and has been around forever.
ArkansasFordMan
Better shift points
Monsta's Avatar
Monsta
Sit. Stay.
Better shift points
Look into a Diablo Shift valve or Sonnex valve for the tranny. It'll firm up the shifts.
Monsta's Avatar
Monsta
Sit. Stay.
Better shift points
Old May 13, 2003 | 01:39 PM
Monsta's Avatar
Monsta
Sit. Stay.
Better shift points
Whoa. Whoa What What happened happened??
ArkansasFordMan
Better shift points
I believe that you should be able to get a shift improver kit from any reptuable transmission company. I think B&M would be a good place to start. They have been around forever and have a long reptution for perfomance transmission upgrades.
Old May 13, 2003 | 01:55 PM
Karic's Avatar
Karic
Better shift points
I'm sure I'll be corrected if I'm wrong on this, but I was told the tranny can "learn" your shifting preferrences. If you drive relativley easily, that's the way the trans shifts. If you drive harder, the trans will shift harder.
Wouldn't it just be as easy to disconnect the battery and "re-train" the transmission.
On another note: I had an "RV" shift kit installed in my old '95 F250 for a more solid shift pattern. Cost about $300CDN.
Rick
Old May 13, 2003 | 02:33 PM
ArkansasFordMan
Better shift points
Sorry about all the double posts guys, my computer was really acting weird there for a little bit, but I think it is ok now....I hope
