Exhaust
Old Aug 17, 2012 | 03:57 PM
White Boy's Avatar
White Boy
Exhaust
i have a 1978ford f150 400 with headers looking to do the exhaust new..what the best route to go to get that mean sound im looking for. and is having a H pipe put in will that help with the sound im looking for. thanks
Old Aug 17, 2012 | 04:13 PM
HIO Silver's Avatar
HIO Silver
Too open ended of a question.. much to choose from like tubing size, mufflers, and where it terminates.
Here's my rig: 390FE, Hedmans, 2.5-inch mandrel bent tubing through Moroso Spiral Flows, and terminating at a NASCAR-style boom tube exhaust tip in front of the right rear tire.
<embed width="440" height="420" type="application/x-shockwave-flash" src="http://v5.tinypic.com/player.swf?file=34gpukh&s=5">
Old Aug 17, 2012 | 04:30 PM
hivoltj's Avatar
hivoltj
Flowmaster Delta 40's dual 3" with a 3" h-pipe, exit of your choosing.
(waiting for someone to tell him he'll lose low-end with this setup)
Old Aug 17, 2012 | 11:15 PM
jgavac's Avatar
jgavac
I think 3" is a little large for a 400 unless it built up
Old Aug 17, 2012 | 11:30 PM
HIO Silver's Avatar
HIO Silver
True. These rigs aren't high revvers. In principle, 3-inch tubing from the collectors into a dual inlet muffler with 2.5-inch single outlet is acceptable. Same with 2.5-inch tubes into dual inlet muffler with a single 2.25-inch outlet.
But hey, dual exhaust is much cooler and gives the rig street cred...
Old Aug 17, 2012 | 11:49 PM
jgavac's Avatar
jgavac
I'm a fan of 2-1 and single pack... but I have stock manifolds. If I had headers I would run dual packs
Old Aug 17, 2012 | 11:55 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Is your truck 2wd or 4wd? If they are chassis exit (inside the frame) you have to contend with the trans crossmember first, your collectors are probably 4" to 6" or less from it right?
Dvrs side come over by the pass side pipe, and both down the r/h side of the xfer case (above the crossmember), then split one over to the other side.
Turn out in front of the rear tire, saves bends and pipe which ='s money saved. I hear Flow Master 40's are nice, but they are a little $.
Old Aug 18, 2012 | 07:13 AM
White Boy's Avatar
White Boy
Truck is 4x4. I have 2 1/4 pipe and 2 1/4 purple hornies. And i want it to exit out the rear of truck
Old Aug 18, 2012 | 07:34 AM
Blue and White's Avatar
Blue and White
Hooker has a decent 2 1/4" kit dual kit for. Its made to accept turbo muffs purchased separatly. Have a look at Summit.
Old Aug 18, 2012 | 07:49 AM
White Boy's Avatar
White Boy
Should i do a h pipe
Old Aug 18, 2012 | 12:54 PM
NW 150's Avatar
NW 150
I have headers to 2.5" pipes and flowmaster super 10s and its real aggressive/loud.
Old Aug 18, 2012 | 03:14 PM
77&79F250's Avatar
77&79F250
Run some true duel pipe above the crossmember then put the H pipe aft of that to equal the sound out (so I hear) and keep going towards the back, you want it straight out the back or turned out behind the rear tires?
If you have the side fuel tank both pipes will have to go down the passenger side, also have it start to turn out once above the axle so it will not be hanging under your gas tank.
That can clearance issues and makes for a PITA to drop the tank.....
Purple Hornies ought to sound nice?
Old Aug 18, 2012 | 03:26 PM
jgavac's Avatar
jgavac
A exhaust shop told me that you want to have the h pipe before the muffler, close to the engine. If the purple hornies you have are header mufflers, you can't have an h pipe.
Old Aug 18, 2012 | 03:34 PM
White Boy's Avatar
White Boy
There not hornies that mount on headers.
Old Aug 18, 2012 | 03:38 PM
77&79F250's Avatar
77&79F250
Yes I agree with the the muffler shop said on placement of the H pipe, dought there is room at the collerctors due to the crossmember? Just get the pips past it and then H pipe it then put them PH's on there.
