Another door sticker request
Old Aug 15, 2012 | 09:18 PM
agrove83's Avatar
agrove83
I just purchased a 96 supercab F250 4X4. And i was curious as to what info i can get from the door sticker. I have checked and cant find much about the codes that are on the sticker. Thanks for any info
Old Aug 15, 2012 | 11:15 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
1996 F250 PICKUP SUPER CAB 4X4
Built: March 18, 1996
Paint Code: LE
Trim Code: RV
Gross Weight: 8,800lbs
Original options on this vehicle
47,917 vehicles matching your year and description in our database.
Code Description
EGAHD 3.55 FINAL DRIVE RATIO
TR0DE 4 SPD AUTO TR-NAAO E4OD(4R100)
EM0B0 49 STATE/FEDERAL REQUIREMENTS
EN0VK 5.8L OHV EFI NA V8 GAS*NP
EJAJF 6250 LB(2834 KG) REAR AXLE ASY
D2XE2 7.0 X 16" FORGED ALUM WHL
JCBAB AMBIENT LIGHTING
BLDAB CHROME-PLATED
AAMAB CONVENIENCE GROUP
D3MAD CONVENTIONAL SPARE TIRE
BSDAD DRIVER POWER MIRROR
IBAAG ELECT AM/FM/STEREO/CASSETTE/CLOCK
EGLAB FORD/VISTEON AXLE VENDOR
CLFAE FRONT BUMPER-STEEL-CHROMED
CLVAB FRT LICENSE PLATE BRKT/HOLDER
HTAAC HEAVY DUTY BATTERY
AAGA1 KENTUCKY TRUCK PLANT BUILD
000KV LAPIS BLUE
BMLAE LOWER B/S MLDG
D3JUE LT235/85R-16E BSW A-T TYRES
FMLAD MAN TRANS CASE & AUTO HUBS
AC0B0 MANUAL AIR CONDITIONER
EGJAB NON-LIMITED SLIP REAR AXLE
BSFAD PASS POWER CONVEX MIRROR
ABKAB POWER EQUIPMENT GROUP
CLMAE REAR BUMPER-STEEL STEP-CHROMED
PNKKC ROYAL BLUE
BWDAB SEAT MATERIAL-REAR CLOTH
GTDAB SPEED CONTROL
GRAAC TILT STEERING WHEEL
C1CAE TRAILER TOW HEAVY DUTY
GBCAB WITH AUXILIARY FUEL TANK
DWCAB WITH HANDLING PACKAGE
BHEAB WITH NOISE INSULATION PACK
BLBAB WITH RUNNING BOARDS
DAAAD WITH SUPER ENGINE COOLING SYSTEM
BYBAA WITHOUT 2ND ROW REAR SEAT
BYCAA WITHOUT 3RD ROW REAR SEAT
AALAA WITHOUT SPECIAL EQUIPMENT PACKAGE
nice truck.
Old Aug 16, 2012 | 06:36 AM
agrove83's Avatar
agrove83
Thanks for the info. Didn't realize my truck had so many options. Every day it looks I a better deal.
Old Aug 16, 2012 | 10:32 AM
ntruderrider's Avatar
ntruderrider
Where did you get the info?
how would I find out about my truck? is there a website? fairly new to this truck and fords/diesels
Old Aug 16, 2012 | 01:05 PM
Evan_P's Avatar
Evan_P
Old Aug 16, 2012 | 01:32 PM
ntruderrider
One more ??
this list options, how do I know what was installed, my shows three axle options, on the door sticker under Axle is "C5"do you know what that means?
Old Aug 16, 2012 | 01:58 PM
FORDF250HDXLT
that one can be found here:
What rear end ratio is in my Ford , do I have positraction? - Drivetrain.com
Old Aug 16, 2012 | 02:06 PM
ntruderrider
I lied, another question
So, I have a 4.10 Limited Slip rear end, this truck will see some towing but mostly Highway and back up DD. what would be the prefferable set up here?
Is this something a mechanically inclined person can change?
Do I have to change rearends?
Do I leave it alone and look else where to increase MPG?
Currently at 2500 RPM I am running 76 per speedo, I get about 13 MPG, I need better milage so any advice would help.
thanks for the link, ya'll are a font of info
Old Aug 16, 2012 | 02:34 PM
FORDF250HDXLT
slowing down drastically will be the biggest help.can you stick to 55mph top speed? you'll see a large gain if you can.
if you must drive these speeds,you can't overcome the wind drag,but swapping the rear axle to one with 3.55's is the cheapest solution.you'd have to swap the front pumkin to match too though if you've got a 4wd.
build a low custom front air dam will really boost economy too at those speeds by forcing most of the air to the sides rather than under the aero unfriendly under body.combine an air dam with 3.55 swap and you'll really boost out there on the hwy.
for a truck used for occasionally towing only,it's a no brainer to run 3.55's instead of 4.10's though yes.
for that matter if i had a mostly hwy dd driver, id want 3.08's (no longer sold for this axle though.) wouldn't be much fun for any serious towing though and you'd wish you had your truck back anyway,even if the 3.08 ratio was still offered.3.55's are still a very good all around performance gear.it's not like that's a eco car ratio or anything.it's still well within "real truck" performance levels,just not a match for towing performance of the 4.10's or lower,but like i say,since that's not your norm,you won't care if she starts out and pull hills as strong for those occasion tows when it could mean (depedning on how you drive) saving hundreds per yr in fuel.
all depends on how much you drive too.if i didn't drive much, a 460/c6 truck would be just fine.since i drive a alot,that old school setup would cost me thousands per yr more than the diesel/e40d setup.
it's all in how you use 'em and how often.one mans ideal truck could be anothers miserable and costly experience.
CJWisinski
Mar 27, 2019 04:17 PM
vjsimone
Jan 19, 2019 04:25 PM
archerseven
Jul 27, 2016 11:32 AM
Rob89
Jun 10, 2016 08:57 AM
justjake
Nov 29, 2014 11:01 AM
