Also, put an electric fan in with a switch so you can turn it off when you go through deep water and not have to worry about your fan throwing it everywhere.
I run a 16" Rapid cool from Orielly's think it was like 70 bucks, i made 2 back to back pass's the other night hard bogging like 5500RPM for a couple minutes while barely moving and it only got to 195 on the first and about 220 after the second, and my timing was a little off... changed my timing and made my last big tire class went out of course that time but it was only in the 180 range
I finally broke the nut loose with pb blaster.
You can see in the pic theres mud that was caked under the shackle. Thats one reason I want to flip the hanger.
Now I have some questions.
Sould I take the bolt out holding the front of the spring on?
Do I need to take the axle off the springs?
I ran two Taurus fans on my wheeler, wired up so I could run them in high or low, or off of course. They moved tons of air, but when I was in the deep stuff, they would get dirty/muddy/water in them and I had to replace them, along with the alternator almost yearly.
