Sponsored by: Real Truck
clicking/wait to start light problem
Old Aug 15, 2012 | 01:18 PM
AKFORD4x4's Avatar
AKFORD4x4
so just recently when I turn key to on position there is a fast repetative clicking coming from behind the dash and my "wait to start light" wont come on. I sat at the gas station yesterday for 10 mins and finally after cycling the key on and off I got lucky and the clicking stopped and wait to start light came on then the truck started. This morning same thing.......clicking finally stopped, light came on, I waited for light to go out and it fired right up. HELP???
Old Aug 15, 2012 | 01:24 PM
AKFORD4x4's Avatar
AKFORD4x4
oh and FYI while the truck is clicking the needles on my gauges are jumping around
Old Aug 15, 2012 | 02:34 PM
MrShake's Avatar
MrShake
Have you checked your Batteries? Sounds like a voltage problem to me.
Old Aug 15, 2012 | 02:45 PM
AKFORD4x4's Avatar
AKFORD4x4
ive been researching and Im gonna check batteries next
Old Aug 15, 2012 | 03:01 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Have the battery "LOAD TESTED" with it disconnected from the vehicle, but with a FULL CHARGE.
Old Aug 15, 2012 | 03:57 PM
AKFORD4x4's Avatar
AKFORD4x4
batteries tested at a little over 12 volts each so they are good. I found the clicking to be coming from underhood fuse relay #4........not sure what it does but I replaced it and now there is no more clicking and truck starting fine so seems like that problem resolved. NEXT issue is that my Alternator is only 3 months old but it putting out 15.8 volts to both batteries!. I have recently been having a flashing OD button problem and code said P0720 which was OSS sensor, I replaced that and still same problem, I read that a bad alternator can have interference with the tranny sensors causing problems such as mine.....maybe my alternator is my issue on that. Opinions?
blue1ton
May 29, 2012 04:31 PM
Midwest Dually
28
Feb 22, 2011 05:53 PM
Torrence
32
Sep 7, 2009 12:04 PM
1995sho
Sep 10, 2007 03:16 PM
