Temperature gauge ?
Old Aug 13, 2012 | 09:25 AM
Rnager D's Avatar
Rnager D
Temperature gauge ?
Newbie to the forum. 1991 Ranger STX, 4.0. Had a leak from the rubber seal on the thermostat. Changed the thermostat (stat 195) and seal. Now my temperature gauge is not showing a constant reading, goes to half way and when the thermo opens the gauge falls down to a quarter. The gauge is cycling this way every time the thermo opens. Any help/suggestions will be appreciated. Thank you for your time. Don B.
Old Aug 13, 2012 | 10:19 PM
Rangerman Stan's Avatar
Rangerman Stan
Try to make sure your coolant is topped off to about an inch below the radiator cap. Check coolant level when the engine cool so hot coolant won't blow out all over you and everything else. That's the best time to add coolant too. Keeping it full will help push out any air that may be trapped in the thermostat area, and help reduce the cycling.
Old Aug 14, 2012 | 02:28 AM
g_k50's Avatar
g_k50
Sound like your gauge is working correctly.
Shows hot when closed and then the cooler water from the radiator enters when the thermostat opens and it reads cooler.
Replace thermostat with correct temp from Ford.
Are you sure it's dropping when the thermostat is opening? How do you know? Check coolant for combustion gases.
quakerj
Dec 24, 2014 12:43 PM
swirlparanoid
Mar 16, 2014 10:22 PM
Major Marvin
34
Feb 14, 2011 01:04 PM
Captbo2001
May 10, 2006 11:48 PM
fishindave11
Bronco II
Jul 18, 2005 10:43 AM
